That picture is horrific!![]()
OldPath must still be out cleaning up, he hasn't posted since Tuesday. If he doesn't show up soon I may have to go knocking on his door.
THAT threat should get his attention.
Beautiful spring weather out here this week
THAT threat should get his attention.![]()
I’ve never seen a kinetic splitter beat a 4 way hydraulic that’s cycling in the 10 second range. And a hydraulic lift on the 4 way will significantly cut down on the mess.(I have guys tell me a super split is better, because it doesn't make so much trash. Then they brag how their SS will split little pieces, to start their fires with.
WELL, that trash under the grate of my splitter, is PERFECT for starting fires with! NO extra splitting is needed!! )quote
I have a SS and it always leaves a nice small pile of kindling under it. As for using one of the SS splitters. You won't find a hydraulic splitter that can keep up with it unless it is splitting rounds into 8ths. I do have a 3pth hydraulic splitter that rests on the ground for the big stuff that I can't pick up.
That must be a very nice setup. Is it a wood processor?I致e never seen a kinetic splitter beat a 4 way hydraulic that痴 cycling in the 10 second range. And a hydraulic lift on the 4 way will significantly cut down on the mess.
