Pole building or metal building
   / Pole building or metal building #1
Mattyboy93
Member
John Deere 770
Looking to spend this stimulus check pole building or metal building is what’s holding me up..
I’ve noticed metal buildings are a bit cheaper than a traditional pole building..
What are perks of one over the other?
Is one better than the other?
Are these metal buildings advertised sturdy?
   / Pole building or metal building #2
I would think a pole barn would be longer lasting.The metal buildings I have seen just sit on top of the ground.Both will have some condensation problems,depending on your climate.I have about $13,000 in a 24x32x12 ft.pole barn.Single 12x10 over head door with opener,four windows and man door;no concrete.
   / Pole building or metal building #3
Metal buildings usually require more foundation work. The metal posts have to be bolted down to concrete block poured / buried in the ground. Pole barns have wooden posts in a hole back filled with dirt. I looked at both and am building a 30x40x12 pole barn this Spring. Dug the holes in December before the ground froze and now am waiting for the holes to dry out. They have 1-2 feet of water in them from Spring rain and snow (5 inches last night). Paid $13K for all materials including metal siding and roofing with 2 9x10 overhead doors.
   / Pole building or metal building #4
It really depends what you are going to use the building for. If it is just for storage and your ground is pretty stable a pole building is fine. With a metal building the slab is part of the strength of the building (all of the uprights are bolted on) so it really needs to be done right. I am in the middle of building a 40x100x16 with a 4/12 pitch roof and 4 roll up doors. Slab took 12K pounds of rebar and 130 yards of concrete and cost right at 40K, the building kit was $25,500 plus tax and then I added an additional 12x12 roll up door for another $700. Foam board insulation and some windows is going to add another $4500. Then add electrical and a little plumbing down the road. I think a good metal building on a good slab should last indefinitely, pole barns around here all seem to suffer from rot/termites sooner than you would expect.
   / Pole building or metal building #5
I built a Chief Steel Building a year and a half ago: Chief Buildings | Trusted. Tested. True.
30x60x16 4/12 pitch like Mickey
It's awesome and I love it.
I would do it again in a heartbeat.
Steel is strong as steel.
   / Pole building or metal building #6
I am in MA and thinking about this process, what company did you use if you don't mind me asking.
   / Pole building or metal building #7
We chose a Morton building in 2007 30 by 40 still happy with our choice
   / Pole building or metal building #8
There is a Morton Buildings office close to you, in Westfield, Ma. (413-562-7028)
I have a 36x48x14 Morton (on Cape Cod) that is now 39 years old.
I love it!
Morton ain't the cheapest, but is VERY high quality.
Wonderful people to deal with!
   / Pole building or metal building #9
I love it!
Thank you!
   / Pole building or metal building #10
I am building it myself. I bought the plans and materials kit from DIYPoleBarns.com out of Ohio. They ship you everything you need, all wood, posts, metal, trusses, nails, screws, concrete pads, doors, tracks etc.
UNUSED RAYTREE RMSC78 - 78" SOIL CONDITIONER (A54757)
UNUSED RAYTREE...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
