Pole building or metal building
   / Pole building or metal building #11
I am building it myself. I bought the plans and materials kit from DIYPoleBarns.com out of Ohio. They ship you everything you need, all wood, posts, metal, trusses, nails, screws, concrete pads, doors, tracks etc.
Besides regular tools, I'm guessing a lift and a post hole digger are needed? Trying to thing if this is something I could do, or at least do most of myself.
   / Pole building or metal building #12
If you do order a materials kit for a do it yourself job, be very careful about the material thickness.
I believe that Morton Buildings uses 19ga. sheet steel, which I doubt that any others do.
A cost item for sure, but most importantly, a VALUE item.
   / Pole building or metal building #13
Build it with steel, build it to last.
I have both. The pole building has a warmer feel to it.
Pole: Good: Warmer feel, if it burns it all goes which is good, easy to add things, does not sweat as much in damp climates Less good: just not as durable as steel, less airy you don't get the big cathedral effect, eventual rot, a tornado will pull the poles out of the ground unless you put a footer on them, set 5' deep and concrete then the barn will blow down but not pull out
Steel: Good: Clear span and lots of loft space possible, durable Less good: Require an expensive foundation at the start unless you build like I do with pipe columns, sweat, not as warm feeling, harder to make additions unless you weld
Whatever you do INSULATE THE ROOF even if it is an open side building and even if you just use foil and thin foam. Unless you live in a desert it the tin will sweat and it may even rain in your building.
I build with steel. When I'm done it is going to stay there. I just like it better though I do like post and beam for the aesthetics.
It will take more than your stimulus check to build a decent building.
   / Pole building or metal building #14
I have a rep from Morton coming out tomorrow morning. I want to hear what they have to say and get a solid figure on what I am looking for. Then I can shop around a little and decide if the premium they offer is worth it. .
   / Pole building or metal building #15
You may not agree, but for ME, the Morton price/value most certainly has been worth it.
39 years and counting, without a single issue, and I am a perfectionist!
You can likely buy a cheaper building than a Morton, but you cannot buy a better building!
If you haven't done so already: Check out the Morton website.
   / Pole building or metal building #16
That's what I keep hearing and seeing. I like what I see on their website and their rep has been very responsive. They are my number 1, I just want to get some better figures so I can make sure I'm 100% prepared and aware of what they are delivering and what I need to do.
   / Pole building or metal building #17
I am a happy Morton building customer as well. Built 18 months ago, 30x50x16. 1 14x14 rollup and 1 12x12 rollup and 1 36" service door. No windows, 3 roof skylights, 32" osb protective interior wall liner, 12" vented eave overhangs and vented roof ridge. Just the building and doors was $38,000. Concrete was $4,000 and underground electric was $4,000. You have to compare apples to apples in regards to what materials are being used when getting estimates. Morton uses 19 gauge steel for roof and siding. 50 year transferable warranty, all lumber is #1 SYP. They make all their own laminated post and trusses. They don't put wood post in the ground anymore. They have there own 'Perma column' concrete footings that the post attach to. They provide a construction material dumpster, porta potty, all there workers are employed by Morton . It took them 6 days ( 2 guys ) to build the barn. I would inspect each day after they left and then if i had issues they would fix the next day. They are a first class builder. Good Luck !
   / Pole building or metal building #18
I don't think you could do it by yourself as a one man operation, but with 2 or 3 yes. Holes can be dug with a skid steer with hydraulic auger or excavator. I don't think a tractor with 3 point auger is going to dig 20" holes 4' deep, not in New England soil. I had mine dug with a 70,000 excavator. One scoop per hole. I have a friend at church who has a telehandler and we will use it to put the trusses in place. I have seen Youtube videos of it being done with manpower only, but my trusses are 34' long and the walls are 12' high. I would rent a lift to get the job done in a couple of hours. I do plan on having a work party with 10-12 people on truss day as many hands make light work. Guys at the firehouse and at church have all asked if they can help.
   / Pole building or metal building #19
I'd be interested in your quote. I had a Hansen builder quote me $35K for my 30x40x12 barn.
   / Pole building or metal building #20
Double Post.
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR LHR-WS22 WEBBING SLINGS (A54757)
UNUSED LANDHONOR...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
197711 (A51244)
197711 (A51244)
