Pole building or metal building
   / Pole building or metal building #41
I got a quote back for a 42x48x12. (2) entry doors (2) 10x10 garage doors, all insulated. (4) windows and insulated roof- 70k.
Fully insulate the interior and finish the inside with plywood and acoustical steel, 88k.
That's a pretty chunk of change, but they have a good reputation for quality buildings.
   / Pole building or metal building #42
I know it must seem like a lot, but they do EXCELLENT work, and a pole barn is a lifetime structure.
Go with the complete job if you can afford it.
I didn't do that,.....but should have!
   / Pole building or metal building #43
I think we will go with them, I just won't be doing it today. When I reached out I told them I didn't want to get started on anything until this fall. The gentleman wanted to come see the site and put together a quote so we would know what we were looking at. We just built a home last year, and I wanted to spend the next couple months paying off a few small things, then get into the barn.
   / Pole building or metal building #44
Get your free coffee mug and sign ....................
   / Pole building or metal building #45
Well ****, if the salesman told me about those perks I woulda plopped a downpayment right then and there! :laughing:
Interesting I definitely need to do some more thinking about which way I want to lean... paying for the slab up front may be off the table right this second so i might lean towards the pole building side since it the size isn’t going to be as large as some have built here.. especially since I can add the slab down the road... if I tar the posts before sinking them into the dirt.. wouldn’t that help prevent rot?
   / Pole building or metal building #47
Should you tar the posts before sinking?
A lot depends on the type of pressure treating used.
If you get direct burial material, I don't think tarring would be warranted
   / Pole building or metal building #48
The posts I bought for my pole barn are guaranteed for 50 years. They are triple 2x6 laminated into a post. I asked the company if I should tar them or use plastic sheaths. They said it is unnecessary, and they offered the sheaths as an option.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
More info coming soon! (A50323)
More info coming...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2007 FORD F150 XL TRUCK (A51406)
2007 FORD F150 XL...
2018 HINO 338 18' BOX TRUCK (A54607)
2018 HINO 338 18'...
