What is the capacity of this pump?
   / What is the capacity of this pump? #1
BertZegers
Gold Member
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
I recently bought a Case 1816C skidsteer. The pump for the cylinders is noisy, and I think the replacement is DFE080 (9-12390) Surplus center.
The question I have is what is the displacement of the old pump?
REXROTH 05098 S12SX50AK55R
I read somewhere that it is 8 Gpm at 1100 PSI at 3600 RPM, but want to be sure.
   / What is the capacity of this pump? #2
Call a hyd shop with those numbers its a Rexroth pump.......
I could order the pump from the dealer as well, but big $$$$$$$$$$$ in Canada.
I am hoping to get the info from this forum, and order an after market (from US). That is why I ask.
   / What is the capacity of this pump? #4
Ask them what the output is....
   / What is the capacity of this pump? #5
according to my old Rexroth literature that should be 0.58 cubic inch per rev, right hand rotation, with side ports but the X in the model code indicates a non-standard option so not 100 percent positive on the displacement.
   / What is the capacity of this pump? #6
Since you're going to replace the pump anyway, you could just open the pump to get the measurements needed for this calculator on Surplus center: Surplus Center
oldnslo thank you, that helps.
   / What is the capacity of this pump? #8
0.58 ci/rev works out to 9.0gpm without losses. With typical gear pump efficiency and some belt slip you would be right at 8gpm. ISZ
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
WOODS RT48.30 LOT NUMBER 234 (A53084)
WOODS RT48.30 LOT...
