Valvoline premium blue 15w-40
   / Valvoline premium blue 15w-40
Run the Extreme 5W40, you can run it year round with no worries. We have been running T6 or Premium blue extreme since the first service on the 1635 with zero issues.
Thanks Will, I will look for it. I haven't found it locally yet.
FYI. Valvoline blends all of Kubota's branded lubricants, SUDT included.
Didn't know that. Thanks for sharing the information! I will share it with my neighbor so he can save some money.
You don't want to be changing oil with the seasons, especially if your not putting that many hours on it. That gets expensive, is a PITA and is totally wasteful. Use a weight range that works summer and winter for you based on lowest and highest temps you'll "start" your tractor in. If your storing it in a somewhat or even unheated building the starting temps will be very different than the outside temps. Check it and see. I do agree that a 5W or 0W-30 will likely work best for you depending on conditions. Next would be a 5W-40.
Cheers,
DEWFPO
It will be stored in my garage so than you for the recommendation. Once I am done with this oil, I will settle on the 0W-30 or 5W.
You will be fine with the 15w40 oil.......
Thanks!
Just a general question. Do you guys change the filter with every oil change? The filter said change every 300 hours. I mean, its cheap enough to change with every oil change but I wonder if people leave it in for more than 1 change.
   / Valvoline premium blue 15w-40 #15
Thanks!
I change the oil plus the oil filter every 200 hours on my small tractor L3800 Do you have the book on your tractor ?
   / Valvoline premium blue 15w-40 #16
I change the filters at the factory recommended service interval. DEWFPO
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2010 International Prostar (A47477)
2010 International...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A53422)
2015 Peterbilt 337...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
