5220H fender is touching the tire.
   / 5220H fender is touching the tire. #11
Front tires look ok, back tires are way over inflated. Hard to tell if rear pic is from camera angle or if right fender is bent down. Since the right is the one that's rubbing and left isn't, maybe fender is bent?
How much air is in those back tires anyway?
Are they filled with fluid too, or just air?
   / 5220H fender is touching the tire. #12
The right fender definitely appears bent in the photo but I am with Slim it could just be camera angle. I wonder if there is a loose or missing bolt in a bracket on the right side allowing it to drop down. :confused3:
   / 5220H fender is touching the tire. #13
Wow, If you live in snow country and ever wanted to put chains on... major surgery might be in order.
   / 5220H fender is touching the tire. #14
Yep, chains tend to make their own clearance.
Gehl 960 Silage Wagon (A50515)
Gehl 960 Silage...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
7046 (A50322)
7046 (A50322)
