F series question
   / F series question #1
om21braz
Lexington, NC
Does anyone know what F series began having a deck that will pivot up 90 degrees for clean-out? FXX60, 80 or not until new 90?
Sorry, but I researched thru a fair amount of previous threads without finding an answer.
   / F series question
That is more than I did know - Thank You! Been looking for a while and saw a video showing a new F2690 and how the deck pivots up. I think that is must have feature. My present ZD has the pivoting axle & jack, but you still have to get under it to clean the deck out.
   / F series question #4
I have the f2690 and it has the deck that lifts. I ordered mine with the 72 inch deck, and for me it is a bear to pick up to service. Mine has the mulching kit on it so grass does accumulate, so of course that makes it heavier. It could also be as you get older those types of chores get harder.
   / F series question #5
You had better believe it
   / F series question #6
   / F series question #7
Do the new ones swivel up without having to disconnect the drive shaft?
I don't disconnect my driveshaft , just position so the opening in the u
joint is in the bend as you rotate it up.
   / F series question #8
the first ones were the FZ2100 & FZ2400 zero turn F series mowers from back in 1992, I was lucky enough to be present when they brought the prototype to our dealership to show.
Was never offered again until the newer models of today
   / F series question #9
F3060 was sold from 1996 - 2005 and the deck lifts up hydraulically & swivels 90 degrees relatively easy for service. No need to disconnect the driveshaft.
It's a 72 inch rear discharge deck.
I have not had to deal with much built up grass underneath so far, but if that ever becomes a problem I will rig up a small chainfall to assist swiveling the deck.
View attachment Kubota - Prior Prorducts F3060 Specs 1996 -2005.pdf
   / F series question #10
Here is what it looks like.
It is true, with a 72 inch deck the front drive wheels of F3060 have to be 2 - 3 inches elevated, in order to lift the rear anti-scalp wheels off the ground so you can swivel the deck all the way & lock it in place.
:silly: Not a big deal once you figure it out.
2007 Ford F-350 Pickup Truck, VIN # 1FDWW37P77EA65949 (A54865)
2007 Ford F-350...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A54865)
New/Unused 72inch...
2004 CASE 40XT SKID STEER (A52707)
2004 CASE 40XT...
