would you use this bush hog?
   / would you use this bush hog? #41
Free bush hog? heck yeah, fix er up for small change and you save hundreds. :thumbsup:
   / would you use this bush hog? #42
Plus 1 on Don't Overthink This!
   / would you use this bush hog? #43
Much better looking than the one I run every spring. :) Check your cotter pin on the nut that holds the disk and blades and grease the universal. GTG. :)
   / would you use this bush hog? #44
I would love to have a brush hog to do rough cuts with.. First pass in the spring (when it gets here) on some trails I use, moving back bush as it encroaches on areas I don't want it, last pass over trails in fall..
I would give it a tune up and try it in a heart beat..
   / would you use this bush hog? #45
If the gearbox is empty dont fill it with gear oil. Its common to have a pinion seal that leaks. Fill it with John Deere corn head grease.
Stays a grease till it warms op and turns to a oil. When it cools goes back to a grease. Doesnt drain out then.
The stuff is like a miracle worker for gear boxes.
   / would you use this bush hog? #46
Great tip!
   / would you use this bush hog? #48
Still leaks while runnin :laughing:
ok everyone, thanks for the help. i bought a new 3025e today, should be delivered within two weeks. i got the telescoping arms instead of the quick hitch.
do i need a slip clutch for this thing? tractor has a hydrostat. or is there a shear bolt somewhere?
once i get the tractor i will pull this thing around to the shop and get a better look.
   / would you use this bush hog? #50
Looks like it has a slip clutch from the picture but hard to tell....
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2014 International Derrick Digger Truck (A55973)
2014 International...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
66'' SKID STEER BUCKET (A56857)
66'' SKID STEER...
