What do I do with this 8 month old John Deere tractor and loader
   / What do I do with this 8 month old John Deere tractor and loader #11
Bummer. Touch it up and move on. In my opinion it's not a hill worth dying over.
   / What do I do with this 8 month old John Deere tractor and loader #12
Years ago I had something similar on a Kubota Grand L 4310 HST Cab paint peeled off in big strips on the inside back wall of the bucket on the loader and underneath where it peeled was all rust tractor was ordered new from the dealer and was always stored inside when not being used.
Trade it in on a Kubota.....lol Actually, looks like poor paint and metal prep to me but then modern top coats are very brittle anyway. You can thank the EPA for that. Looks terrible but then it is a tractor, not a Ferrari.
Good luck with getting it repaired. I'd think the repair (if any) would be less durable than the OEM topcoat.
I considered the Kubota, even though I'd need all new front loader attachments, but the deciding factor was due to the familiarity I have with operating my Deere 4600 and the similarity with the new one, especially the hydrostatic. We have a herd of over 150 cattle, and I feed a lot of round bales, which means I also load, unload, and store a lot of round bales, so it's a lot of forward and reverse operation. The single pedal of the Kubota would be too drastic of a change for me to switch between the two tractors as I do.
The new tractor also has a very uncomfortable cab. My one leg hits the parking brake and the other leg hits the sharp edge of the joystick lock. My steering column has a lot of slop in it, probably some loose bolts somewhere, and it seems that after I've been working it for a few hours with fairly heavy load, it has no power in reverse. And even worse, the front end loader has a lot of drift, so even without a load on it the loader drops about 1/2" every 15 seconds or so. I saw a post here that there is a valve problem and Deere is aware of it so hopefully there will be a solution to that, but given how poor the response has been from Deere I'm not optimistic. The loader drift is a big problem for me because as I'm feeding hay and have to unwrap the bales the loader drops so fast I can't complete the task without climbing back into the tractor to raise it up again.
I have a lot of background regarding paint and powder coating, and there is no excuse for the poor quality of the paint. The metal wasn't pre-treated properly, and frankly, when you have equipment like this the material should ideally be e-coated, or at least primed, rather than just running bare metal through the powder coat line. E-coat is very environmentally friendly, and there are lots of primers available for powder coating bare metal. If I have to repaint it myself, I can assure you it will be more durable than the OEM topcoat, and seriously consider retaining an attorney to sue the dealer and Deere if they don't take care of all of these issues.
It's all over the front loader. The photos are just a sample of the areas that are flaking off. It would be a constant job every couple of months touching up areas. In my opinion, the entire loader needs to be properly prepped and painted . I'm just wondering if other owners have had similar issues?
   / What do I do with this 8 month old John Deere tractor and loader #15
It's never going to stop rusting until it's properly had the rust removed and correctly painted. If Deere doesn't want to do this I would sue both the dealer and Deere. They have no problems charging a premium price so the least they can do is stand behind their products. The local Deere dealership here has been great to me. Any problem I've had they gladly taken it in and repaired it under warranty even though I didn't buy it from them.
When I bought my X500 it was just under a year old used but still had lots of warranty left on it. The seat had a tear in it like the vinyl coating was too tin in one spot. I bought it from a different dealer who said nothing about the seat being covered under warranty but the local dealer said they would replace it but recommended I wait until the warranty was almost up. A few months ago I brought it down to them and they went through everything and anything that looked like it was defective they replaced. When I replace it I will buy from them. I think your dealer just doesn't want to mess with it. Sad that some dealers are great while others are not.
You would start a lawsuit with John Deere over paint chips on a loader frame?? You and I are cut from different cloth.
The photos are just a sample of the paint peeling from the loader frame. As I said, the tractor is stored inside in a heated building unless I'm using it. I will definitely sue if they don't address the issue, and the paint peeling is not the only issue. Obviously my dealer isn't very responsive either, but there isn't a lot of competition here.
   / What do I do with this 8 month old John Deere tractor and loader #17
I ABSOLUTELY WOULD sue over "paint chips"
That is one he11 of a lot more than just "paint chips"!
It needs to be documented that both the dealer and JD, refused to remedy the paint issue.
If I were the OP I would then take the loader to the best/most expensive paint shop I could find.
Have the loader sandblasted, etched, primed, and painted with the best epoxy paint available.
I would then file suit (within the warranty period if possible) for the repair cost, in small claims court, against JD and the dealer.
If nobody shows up to defend, a judgement will automatically be issued in your favor.
   / What do I do with this 8 month old John Deere tractor and loader #18
I have a 4052R and the paint is good on it. My bigger tractor, a 5100M, does have some paint issues like your tractor. I just prep and touch up as necessary.
   / What do I do with this 8 month old John Deere tractor and loader #19
it's been going on since at least 2007. you'd figure they fix the problem, but NO!.. John Deere tractor paint peeling - Google Search
   / What do I do with this 8 month old John Deere tractor and loader #20
So you've won the judgement, now what. You still don't have any reimbursement of your expenses. Now you have to go to court again, at what point does the cost of attorneys exceed the cost of the repair? And attorney costs are not always paid by the losing party.
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
