Bx1800 Filled tires.
   / Bx1800 Filled tires. #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
My old man just picked up an older BX. Pretty light in the rear. Anyone fill their rear turf tires? I know they are pretty small so not sure if it is worth it. Thanks for any info.
   / Bx1800 Filled tires. #2
really all depends on what you are doing with it.
A smaller tractor like that doesnt cost much to fill the tires. Give it a try to see if it helps.
   / Bx1800 Filled tires. #4
Fill em with water and experiment with fill ratio to see how you like it. You can always put in anti freeze later if you like it.
   / Bx1800 Filled tires. #5
You will find the filled tires make the unit seem less tippy. Up here in the cold country we use beet juice. If you ever get a flat that stuff won’t pollute....although the bears might like it!
   / Bx1800 Filled tires. #6
I filled my Kubota ZTR rear tires. They only took 8 gallons each IRC. 65 lbs x 2 = 130 lbs; still better than a sharp stick in the eye.
   / Bx1800 Filled tires. #7
My BX2230 has filled rear tires along with wheel weights. Hauling a full bucket of dirt, I feel comfortable with it. But I am still cautious when on side slopes. Jon
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
BOMAG BW172D-2...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
