Richard - thank you for the pics and description of what you've done with yours. That sounds like it would work well with mine.
johnnyvol - thanks for the information. I wouldn't have had a clue otherwise, but a cushion valve makes sense!
metalbender - thank you for your thoughts.
After finding a parts manual as suggested (at least one shown on Messicks) it looks like the offset and tilt cylinders are identical, if both are supplied. I may just try swapping the cylinder to the tilt function and moving the ratcheting bar to the offset for the time being. If I end up not using the offset much (I don't think I will, but I may be surprised), I'll just stick with two cylinders and not need anything. Thanks again for the thoughts!!
