International 574 broke the hydraulic pump shaft
   / International 574 broke the hydraulic pump shaft #1
Uruguayo
Member
Uruguay ciudad de Minas
Mitsubishi mt 3501d - massey ferguson 1175 perkins 6.305 - ferguson te20 1951 perkins 4.154 marine adapted - Mf 135 1972 perkins ad 3.152
International 574 broke the shaft of the hydraulic pump !!
Hello friends, I ask you for help, my 574 cut the gear shaft inside the hydraulic pump, the pump is new, I am worried about putting a new pump back and it will break again ... Has this happened to you? pump problem or hydraulic circuit problem? Thank you!!
   / International 574 broke the hydraulic pump shaft #2
When mounting the new pump did youfit a new gasket ?
After removing the broken one did you find stuf inside the pump that could broke it ?
Did you replace the hydraulic filter ? Did you assemble it the correct way ?
The new pump was installed correctly.
With the corresponding stamp.
I found nothing that could cause the breakage, nothing stuck in the gears.
Does the hydraulic system of these tractors have a main relief valve?
   / International 574 broke the hydraulic pump shaft #4
   / International 574 broke the hydraulic pump shaft #6
Sorry ! No 13 go to steering and no 1 is priority valve for steering20200604_123159.jpeg
   / International 574 broke the hydraulic pump shaft #7
If you look under the MCV you will see no 2 can be removed witk a socket and no 1 with a allen wrench
   / International 574 broke the hydraulic pump shaft #8
As i have said relief valve is no 2 and its pilot operated . Meaning it will lift your implement plus say 6 lbs.
There is another valve that will release at a max pressure and that is located infront of your MCV( multipile controle valve) . Thats that valve block where the hydraulic filter is. Next to the fitting with the pipe on it.Image%20(3).jpeg
2020 JOHN DEERE 8R310 LOT IDENTIFIER 221 (A53084)
2020 JOHN DEERE...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
40" EXCAVATOR HYD TILT BUCKET (A51248)
40" EXCAVATOR HYD...
