Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,902
- Tractor
- Kubota BX25
I have a model D55168 oil less compressor two years old. The belt broke on it. Watched a couple you tube repair videos. They make it look easy and that you can just force the belt on w/o loosening the tension cam. Tried several times to no effect. Loosened the adjustment and it is easy to get on and tension up. I spent an hour trying every tg I could think of the get the belt to run true on the pulleys bur it kept running off the edge. Looking closely at the broken belt it appears that is why it broke. The bearing block for the flywheel does not seem to have any play, obviously ball or roller bearings. Can find no info on the internet of the tension process or how tight it should be. I tried may adjustment points but it still kept running off the flywheel. Dewalt uses this belt and tension unit on many of their compressors.
I have replaced flat belts on a variety of things and never encountered such. I was skeptical on the you tube video showing not loosening the tension because have always had to.
Any of my TBN compatriots experienced such a thing? Help!
Ron
Ron
