4-way brass hose splitter, repairable?
   / 4-way brass hose splitter, repairable? #1
ChuckT
Gold Member
Central Florida
Yanmar YM1510D
I have three 4-way brass hose adapters and one appears to be leaking thru one of the 4 outlet ball valves. Are they repairable?
   / 4-way brass hose splitter, repairable? #2
Any pictures of it.......
   / 4-way brass hose splitter, repairable? #4
I swear these things are made to fail after 2 yrs max. Seems like I always have one that the handle is broken on or has a crack or just plain leaks.
At some point building one with hise bibs and PVC is going to be cheaper.
Yes to being throw-a-ways. Drat. Sure looks like the valve guys could be replaced.
   / 4-way brass hose splitter, repairable? #6
I made several like this
DIY Hose Manifolds and Splitters - Applied Paranoia Blog
But used about 4 inch sections in between each fitting. That way I can make at least one replacement or extension.
Since then, none of the factory plastic ones still in use have broken.
Bruce
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2021 Isuzu NRR Heil 9Yd Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Swict 66" Bucket (A50121)
Swict 66" Bucket...
2007 Chevrolet WA4500 Box Truck (A50323)
2007 Chevrolet...
