F935 PTO wont dis-engage
   / F935 PTO wont dis-engage #1
twostickmutt
JD f-935 ford jubilee
i was mowing today and finished the last pass and shut of the mower blades. Headed for another mowing spot and for no reason the mower blades stated turning . the switch was off. i headed to the shop to investigate but not before the pto brake band got real hot so i guess that part was working. i even unplugged the clutch on the end of the crank pulley and the mower still wont shut off. Any ideas ? thank you very much in advance !
   / F935 PTO wont dis-engage #2
:welcome: to TBN
That is puzzling. Sure sounds like a short.. but if so a fuse should blow, I would think.
Do you have a plan to trouble shoot the problem? Or waiting for a suggestion or more?
:welcome: to TBN
I'm hoping for some suggestions. unplugging the clutch and it's still engaged puzzles me. like some one posted maybe bearing seized up in the clutch. thanks
i'll dig into it a little farther today. you're talking about the clutch pulley, correct.........thanks
   / F935 PTO wont dis-engage #6
That's right. You should be able to uncouple the pto shaft under the seat and then work with just the shaft running to the front of the machine. The bearings I'm thinking of are in the pulley on the engine. It's the only thing I can think of that would be causing your problem.
With the key off and the mower pto shaft disconnected you should be able to easily turn the shaft other than the resistance from the belts.
   / F935 PTO wont dis-engage #7
I have a PDF of the technical manual for your 935, shoot me your email if wanted
Sounds like the pto clutch bearing locked up to me too
i messaged you joe with my email. thank you. jim
thank you very much sir !
got it joe. thanks a million. I'll let you guys know what i find.
Mission 6" Centrifugal Pump (A50121)
Mission 6"...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
1275 (A50490)
1275 (A50490)
2021 John Deere 6175M (A50120)
2021 John Deere...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
