MOWING? How close are your passes.
   / MOWING? How close are your passes. #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
No one ever seems to talk about this. Depending on what machine I am using, my passes are never very close. I think if I measured it, I might be shocked how much deck width I am wasting. Sometimes it's a case of not wanting to drive on uncut vegetation, or not wanting to cut so close, that you leave a strip and have to go back. Mostly, it's just easier not to have to pay such close attention.
What I'm getting at is that maybe a 60" deck really is only cutting 48" and so forth.
Curious how close other guys make passes.
   / MOWING? How close are your passes. #2
I try to get as close to the edge as I can to reduce wasted passes. That comes from mowing lawns for a landscaper in a previous life, and the owner was a she bi$$$ about efficiency. It also does look a lot better on a lawn when your tracks line up neatly.
   / MOWING? How close are your passes. #3
I mow with the inside of the tire on the edge of the row I'm cutting. I realize I lose some but it gives a nice result with no fringe.
   / MOWING? How close are your passes. #4
It depends how long and thick the grass is for me. Sometimes it's only 3-4". Other times its a foot. I make a pass, and on the next time around if I see clippings from the last pass, I overlap those clippings. If they're gone on the next pass, I stay at that overlap. If there are still clippings, I adjust my overlap. However, we had a very cool wet period where the grass went crazy, so I have to tow the sweeper behind me. Then I just keep the 4" overlap as the sweeper gets it all.
   / MOWING? How close are your passes. #5
Forgot to mention that I have a rear discharge mower as well. It does a good job, but leave a slight to heavy windrow on the right edge.
I find it's different to if you have out front equipment , mid or trailing equipment.
If I have a patch that is just slightly larger than a pass, I often cut that in half. I guess, sometimes with me, it's just about fighting boredom and mixing things up. At the end of the day, I dislike going over ground that is already cut to get to some spot that isn't.
A guy could loose sleep over those split second decisions.
   / MOWING? How close are your passes. #7
Yep. I don't like to go over areas more than once if I have to. It's inefficient. I also don't mow the same pattern each time. I have about 4 different patterns.
If you have windrows, it also increases the chances of matting down grass.
   / MOWING? How close are your passes. #9
Yep. That's why I overlap the windrow and it's gone. If I'm getting windrows, I'll just switch from back and forth to clockwise. That keeps the windrow on the right side and each subsequent pass gets rid of the last one.
   / MOWING? How close are your passes. #10
Those two basically. I don't care what it looks like afterwards. I don't care what the neighbors think since they can't even see my lawn areas. I cut to keep it from getting overgrown, not for appearance. No magazine cover stuff here.
With the riders and push mowers I basically overlap wheel tracks. I try not to do that with the SCUT due to the extra weight. I try not to go the same way over the same spot more than twice if possible when using it.
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
