Does anyone know if the Kubota U17 has a relief valve built into the aux hydraulics? I am looking at a U17 and will want to add a hyd thumb.
Thanks
This is a timely post for me, thank you Ronster.
I have a 2006 Kubota KX41 (3800 lbs) similar size to U17 (3700lbs).
It has an aftermarket thumb, which can easily drive the bucket backwards, and it bends the bucket pin.
I think it bends the pin one way when clamping, then bends it the other way when stowing the thumb back against the dipper stick.
I had to let another operator run it and I did not realize he mashed it hard in the stow position often and habitually.
Then the pin broke the first day he used it (I've been using the machine for 300 hours).
He was an extremely experienced operator and any comment on his methods caused him to do it more, and dig slower etc, so to get the job done I had to keep my mouth shut.
I had to weld the pin twice to keep the job moving.
Of course welding a fatigued pin cannot last very long but we finished the job.
His boss came in for the last day so I just jumped on the machine and told them I'm running it from here on out.
I knew the twice-welded pin wasn't gonna survive long.
I have recently replaced the bucket pin with a new unit and now want to reduce the hydraulic pressure to the thumb.
I tried to figure out which of the (many) relief valves was for the aux (thumb) but couldn't identify which one.
Reducing the pressure at the relief adjacent to the aux did not seem to affect the thumb, but the carriage would no longer rotate (prob not the correct relief).
I don't know how similar the valve stack is on our two machines, but I'm very interested.
Ronster can you remove your floorboards and post a pic of your valve stack?
