pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,210
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
I'll try to answer your questions but there should be people on this forum that know more about this than I do.
A dentent kit is only to hold the hydraulic lever in either the forward or rearward position. You only need one per valve. To me it looks like the bottom valve already has a dentent kit on it. What you need is the lines and the quick couplers for the four hoses off of the valve. I don't know if it's like this for your model but some of the older tractors had a lockout for the hydraulic cylinder that lifted the mower deck. You would lock out the lift cylinder and then use that lever for other accessories. That is with the appropriate quick couplers.
