Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #13,871
Summers here, 96* out with full sunshine and dont look like it'e going cool down for a few days, it sure was hot sawing lumber I couldn't get it all done, I'm so far behind that I'll be doing last years work next year.
Coarse sawing springboard oak makes sawing lumber even more work, I wonder what 40k sawmill do when beams wont stay down so's to re-trim. Got this 6x6-1/4 and it didnt want to stay down unless using the redneck clamping system, then after it was made 6x6 the beam still bent, be fun putting this bridge together.......
Sawing springboard oak - YouTube
   / Tractors and wood! Show your pics #13,872
Pick up a few log cabin screws to try to bring them back in again. It works for boards and that 6x6 oak has to be a lot more flexible, right?
   / Tractors and wood! Show your pics #13,873
Wheres the skeet thrower going? Going for that rustic look by using sawmill slab siding or you ran out of boards, the result of to much cookie making, and its the first roof I seen where post sticking up through. Looks like there room for a soda and coffee machine, I like ginger ale and plane jane coffee and free wifi.
Skeet thrower will probably be on the ground. Nope used those bark less slabs on purpose, been saving them for this application. If you look at the pic, on the far side up high there are rim joists for the sniper tower platform. Temporary Deeluxe Harbor freight roofing system now installed, got family coming this week so I wont be able to finish it right now. Then I'll trim the posts above the roofline and put up the second floor!
   / Tractors and wood! Show your pics #13,875
THOSE are cookies!!!!
   / Tractors and wood! Show your pics #13,876
Interesting to see how many ways there are to make shooting platforms, SC people seem to go all out on that, dont forget ginger ale, on the rocks with straw and lets not go there here.....
   / Tractors and wood! Show your pics #13,877
Your not talking about the $5.00/pc screws are you, dont forget what state we live in............
   / Tractors and wood! Show your pics #13,878
It's not my money that I"m suggesting you spend.... ;)
   / Tractors and wood! Show your pics #13,879
Proof that northern red oaks weigh more the so called upper midwest 4 wheel wagon oaks do, I weighed 3-2x6x8-ish. they added up 141-142 lbs so twice that and it should be around what a 6"x6"x16'-ish weighs, what I dont understand is 140 lbs weighs a lot more now then it did 40 years ago.
My tractor was maxed out on lifting a 2'x2'x8' bundle of red oak slabs.
Heavy red oak slabs - YouTube
   / Tractors and wood! Show your pics #13,880
photos removed
Not only is gravity stronger (as shown every time that I step on the scales) but the ground is much harder when I fall down, than it was 40 years ago.
That bundle of slabs is pretty close to 1/2 cord of green oak... I would be struggling with that load also.
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
2023 Load Trail Tri-Axle 10 Ton Gooseneck Flatbed Equipment Trailer (A55788)
2023 Load Trail...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
