rototiller calls for SAE30, detergent
   / rototiller calls for SAE30, detergent #11
I agree with oldballs.
   / rototiller calls for SAE30, detergent #12
My 1982 TroyBilt rototiller stipulates 30W non-detergent in the gear box.
Nancy - those pictures look just like the Honda engine on my generator. One fill hole/with plug on each side of the engine and the drain hole with its little square plug. I fill until the oil is right at the top of the fill hole.
   / rototiller calls for SAE30, detergent #13
The manual which came with my 1978 Troy-Bilt Horse II calls for 140 or 90 grade in the transmission. On the other hand, the copyright date on the manual is 1991, so it may be a late revision. 30 oil seems pretty light for the bronze gears in there, though.
   / rototiller calls for SAE30, detergent #14
My bad - I checked the Owners Manual. 30W non-detergent in the engine. 90/140 weight in the transmission/gear box.
So, the front orange cap is for engine oil, 30w hd is what I put in last week. Need I be concerned about checking oil for the gear box also?
   / rototiller calls for SAE30, detergent #16
Yes - check the gear box also. The fill plug just might also have a small dip stick attached.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
