Mixed up gasoline cans
   / Mixed up gasoline cans #1
downslope
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have two 5 gallon plastic gasoline containers. One has about 4 gallons of ethanol free 91 octane in it, the other has 4 gallons regular 87 pump gas with ethanol 10-15%. Is there some way to figure out which is which since they got mixed up? I need to use the ethanol-free in the riding mower and since it cost like $4.40 a gallon I'd like to use it for that and not repurchase if possible.
   / Mixed up gasoline cans #2
The corn gas won't bother the mower. That's all I used for years without any trouble.
How much gas do you burn a month? I might consider combining them and just run it. Add SeaFoam or Marvel Mystery Oil.
I wrapped a piece of green marking take around the handle of the cans I use for real gas. Something to consider for future.
   / Mixed up gasoline cans #3
Perhaps a test tube color test. Draw a sample of known corn gas from a vehicle for control.
   / Mixed up gasoline cans #4
Does it really matter? If the non-ethanol is $4.40/gallon and the ethanol stuff is what? $3.30 a gallon? If you replace it, it's costing you less than $5.
(4 gallons * price difference)
   / Mixed up gasoline cans #5
Put a bit of water in a small container, preferably a tall narrow one similar to a test tube. Mark the height of the water on the tube, now pour in 5-10x as much gas, shake and let it settle. If the separation line between fuel and water is higher after letting it sit for a few minutes, it's the ethanol gas. Reason being ethanol will mix with water and separate out..........Mike
   / Mixed up gasoline cans #8
Mix them together and use them up, as has been said a bit of stabil or my favorite additive a bit of 50-1 two stroke oil.
   / Mixed up gasoline cans #9
Seems kinda like trying to pick the fly chit out of the pepper!
JOHN DEERE 85G EXCAVATOR (A52705)
JOHN DEERE 85G...
2019 Dodge Journey Crossroad SUV (A55758)
2019 Dodge Journey...
UNUSED LANDHONOR LHR-SL2T3M CHAIN HOIST (A54757)
UNUSED LANDHONOR...
Wolverine Hydraulic Slope Mower Skid Steer Attachment (A55787)
Wolverine...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2015 Hyundai Veloster Hatchback (A55758)
2015 Hyundai...
