Change oil filters
   / Change oil filters #1
spike42402
rk24
I have an Rural King RK24 tractor an its time for the first 50 hour oil change. Is there a conversion oil filter that I can buy? I can't find the filter number from Rural King. Thanks
   / Change oil filters #2
Many auto parts stores have cross references for oil filters. You might also try to find out who made the tractor. Rural King doesn't manufacture tractors. According to Tractor Data that particular tractor was made by the TYM company. If you find the specific engine in a TYM tractor that should solve your problem. TractorData.com RK Tractors RK24H tractor information
   / Change oil filters #3
Funny how that works you buy a tractor from rural king and you cannot find a oil filter number.Good luck with future maintenance.
   / Change oil filters #4
Many years at ago I had a friend that bought a new tractor from Northern Tool. Although it came with a new oil filter as spare parts he could not find a replacement locally. I ended up machining a metric threaded adapter plate that screwed into the engine block and it would accept a generic Chevy oil filter cartridge.
Hopefully Spike will find the right filter.
   / Change oil filters #5
I'd buy their parts until you are out of warranty so they can't claim you didn't use recommended parts in the event you need expensive warranty service. I'd also recommend keeping receipts for the oil/filters so you can help prove you did the service.
   / Change oil filters #6
Here are the current numbers after buying filters and tran/hyd oil at Rural King:
Hyd Filter:
(Filter is inside the frame ahead of the right rear tire.)
RK # 212160308 on RK receipt & TYM # 11102303100 on filter
Hyd Fluid:
# 3261930 on my receipt.
RK recommends using Harvest King Universal Trans/Hyd fluid for the RK24
Oil Filter:
TYM # 11930535150
Also you can use BALDWIN B1400
   / Change oil filters #7
Magnussom-Moss warranty act forbids that.
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
16ft T/A Flatbed Trailer (A52377)
16ft T/A Flatbed...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
