PTO Power Rake Rental in Catskills NY / NE PA?
   / PTO Power Rake Rental in Catskills NY / NE PA? #1
LMychajluk
Sullivan Cty, NY
Kioti CK3510SE
We're going to have a few trees removed and the stumps ground out. The ground under these trees is a bit hard, but also a bit mossy. Afterwards, I'd like to level the area a bit, add some topsoil/compost/manure, and seed new grass.
We have a 35hp compact tractor, and I'm thinking that a power rake (Harley) would be a good way to do this, but I can't find anyone that rents a PTO-driven one - only skidsteer/hydraulic or walk-behinds (around Sullivan County NY). Does anyone know anyplace that would rent them in the area?
If not, I suppose I can just use a box scraper, maybe followed by a soil pulverizer, both of which seem to be readily available. Having never done this before, any tips on what to use or how?
   / PTO Power Rake Rental in Catskills NY / NE PA? #2
You might just have to rent a skid steer and power rake combo....................Call a tractor dealer and ask if they rent them..........
   / PTO Power Rake Rental in Catskills NY / NE PA? #3
Wow! Those things (power rake) are expensive for a one use attachment. What will you do with it after that? I think I'd get a tiller that will do the same thing at 1/5 the price, new. At least a tiller can be used in the garden, maintaining trails/dirt drives, etc. (Or making new ones.)
   / PTO Power Rake Rental in Catskills NY / NE PA? #4
How are you going to get a tiller to do the same job as a harley rake?
   / PTO Power Rake Rental in Catskills NY / NE PA? #5
Why use a Harley Rake for a tiller job? :D
The OP says the stumps are gone. All that's left is dirt, chips and moss. Why do you need a Harley rake? Did I miss something? :confused:
   / PTO Power Rake Rental in Catskills NY / NE PA? #6
He is wanting to level and rake for seeding
Right... I just want to scratch up the existing ground and spread a bit of new topsoil over it - most of it already has some grass. If anything, if I can't get a power rake, I think a box blade w/ scarifier or land plane before a tiller (there will still be some tree roots just below the surface), and if I was buying, I'd probably get more use out of one of those than a tiller. And I know they're expensive - that's why I'm asking if anyone rents them.
Edit, FWIW:
- Box Blade / Landscape Rake / Soil Pulverizer rent for ~$50-60/day ea., and I can put them in my pickup.
- SkidSteer w/ Harley Rake rent for ~$550/day, plus trailer rental or delivery.
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
ROLLER DOLLY (A53843)
2024 JT8 - 5' X 8' TILT TRAILER (A51247)
2024 JT8 - 5' X 8'...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
