Sonotubes
   / Sonotubes #1
Pettrix
High Desert Southwest
Has anyone poured/used a 12" diameter Finish Free Sonotube?
Looking to pour a column that is 10 feet tall and 12" in diameter and the Sonotube forms allow for a clean finish. I know bracing is vital as is vibrating but just wondering how difficult the process was and how well the removable forms worked?
Finish Free(R) - Sonotube
   / Sonotubes #2
I don’t claim to be a concrete engineer but 10 feet tall seems like a lot to ask from a 12” column.
   / Sonotubes #3
I've used precast columns several times with good success. Because they are circular, they are strong. The ones I used were hollow in the middle and carried a bunch of weight from a front porch roof. Might be less expensive to use those instead of pouring a solid concrete one, with yardage minimums, vibration rental, labor and hassle. A good lumber yard will have several to choose from depending on your application.
Just my 2¢.
   / Sonotubes #5
I'm pretty sure a 10' vertical column is going to need more forming than a 3/8" cardboard tube.
This x2, A guy I know poured 6 foot tall tubes with "some" lumber bracing and it was a nightmare scenario with tubes leaning and even falling.
I saw it after the disaster so I don't know how much support the tubes actually had...beware:eek:
   / Sonotubes #7
I calculated 1.16 cubic yards of concrete which is more like 4000 pounds if my math is correct.
   / Sonotubes #9
Your correct. The formula is pi times the radius squared times the height. I used the diameter of 12 inches instead of 6 inches.
   / Sonotubes #10
A radius of 12" (24" diameter) gives you 4,200 pounds, or 52 80 pound bags.
But either way, I wouldn't consider it without extensive exterior bracing and a rebar cage to be embedded.
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
VOLVO ECR25 EXCAVATOR (A60429)
VOLVO ECR25...
