Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab.
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #22
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #23
I've used Grace Ice an water barrier on the inside the cab of a couple of pickup trucks, the walls, the floor and ceiling if you can. Stick it to everyplace that is bare metal, it's amazing how much it dampens the sound. Vibration = sound
If your not familiar with the product it's a bituminous urethane sheet. You could probably find some scraps on market place from a contractor or homeowner that has some left over.
There are other brands but this stuff sticks like nobody's business!
The adhesion on that Grace water shield is no joke. If it touches itself you might as well cut the piece out because you will never get it apart. That dynomat stuff looks like a pretty nice product. Pricey but I guess I am guessing it is probably top of the line.
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #25
A bit of a different thought. Not real high on the price side either.
Buy dime thick rubber floor mats from your preferred outlet and using a paper or cardboard pattern, cut pieces to fit as tight as possible on your floor pan of your cab. At worse, your feet will thank you if you spend long hours with your feet on the bare metal.
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #26
If the cab has safety glass, it should already be dampening sound. I suggest you ignore the "home remedy" suggestions and use a product designed to dampen sound. It IS ROCKET SCIENCE if you want the best results. It's not cheap or your cab would have come with sound dampening already. If you want the best results, use the best products. Otherwise, stuff your cab with cotton balls. That should help. :p
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #27
There is a lot of discussion on various sound dampening products on this Transit Van board, if you wade into it:
https://www.fordtransitusaforum.com/
You can imagine the problem in a big delivery van with their large expanses of sheetmetal.
One member over there who seemed knowledgeable was a distributor for matting, maybe by 3M. Later I noticed the same guy (probably) here on TBN, using his product under the hood of his tractor with reported success.
On a related note, I wouldn't be surprised if there wasn't a smartphone app sound analyzer to tell you what frequencies are the worst in your cab.
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #28
"smartphone app sound analyzer"
There is, had one on my phone til I ran out of storage due to all the bloatware crap they won't let you delete - mine's Android, try searching for spectrum analyzer... Steve
   / Anybody thoughts/ideas on feasibility of sound dampening aftermarket cab. #29
My 3M Bluetooth muffs work great on my open station equipment. I set the volume on my phone about 3/4 and start up Pandora.
Can still hear the equipment okay but not at the annoying level.
1997 LUFKIN  48X102 FLATBED TRAILER (A58214)
1997 LUFKIN...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
(2) 235/65R17 TIRES (A58374)
(2) 235/65R17...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
