6410 not engaging in forward gear
   / 6410 not engaging in forward gear #11
checked pressure at these ports and both forward and reverse measure right at 100 psi
after about 50 minutes of use fwd drops to 50 and will intermittently pull
reverse stays at 100 psi
what technical manual do I need?
   / 6410 not engaging in forward gear #12
thank you for all your help
   / 6410 not engaging in forward gear #13
The diagnostic manual is TM4572 and the repair manual is TM4574. Do you have mfwd? If so, check clutch pressures with mfwd turned on and off to see if there is any difference. Also try with pto turned on and off.
   / 6410 not engaging in forward gear #14
Just an FYI the manuals TM4572 & TM4574 are for JD 6410 (thread title) NOT JD 6415
   / 6410 not engaging in forward gear #15
i got the power quad successfully out of tractor to disassemble to the forward drum and the piston can i disassemble from the back of transmission or do i have to disassemble from the front?
i have 6415 power quad with left hand manual reverser with 640 loader
thanks floyd
   / 6410 not engaging in forward gear #16
regarding john deere 6415
I have the fwd clutch drum out and will take it apart today I will replace all the piston and seals as I put it back together
I have not yet take apart the front of the transmission should I do that to check things? I have no linings failing that I can see
is there anything out towards the valve body I should check that can be leaking the oil? and oil tubes, plastic parts or seals that route the oil to the fwd clutch drum
thanks for all your help
john deere 6415 with 640 SL
   / 6410 not engaging in forward gear #17
regarding the 6415 john deere
I did not see any change when the pto and or the mfwd was activated I see the pressure blip briefly showing oil change and activation but it comes back immediately
the oil pressure falls off in the forward direction only and will go to 50 or below and stop pulling
I apologize if you get multiple emails I have not learned how to navigate the reply in the tractor by net format
   / 6410 not engaging in forward gear #18
   / 6410 not engaging in forward gear #19
Be sure to check the "drum", I saw a post where they guy found the drum was cracked, causing an internal leak.
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
8" & 10" I BEAMS UP TO 102" LONG (A51247)
8" & 10" I BEAMS...
UNUSED AGT 32-743 60" HYD GRAPPLE (A51248)
UNUSED AGT 32-743...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
(1) VISSANI REFRIGERATOR (1) FRIGIDAIRE REFRIGERAT (A51248)
(1) VISSANI...
