/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #531
How the first one started
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #533
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #534
You’re basically rebuilding the whole deck?
Yes. I will have reused the gearbox (which I'm rebuilding with new seals and bearings), drive shaft, tail wheel, and the front and rear metal bands of the original brush hog. I completely refabricated the sides, top, hitch points (making it QH compatible) frame and the wheel bracket.
Edit: I've modified the design quite a bit because of the way the original failed
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #535
Very nice, I look forward to seeing the finished product.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #536
Nice Mower project cg.
MoMower - you do good work!
My tractor has been doing log hauling and tree cutting duty for the past few weeks-hope to get some time soon for some clearing and trail building,
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #537
Thanks Ken, I usually shut the business down for the winter, the end of October, then I will get on my trail building at home.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #538
So I've completely rebuilt the gearbox with cups, bearings and seals. Given that the bottom seal was toast and the bearing wobbled out and the sleeve worn out they had the gearbox full of heavy grease which had to be scraped and scrubbed and cleaned out. I also had to improvise fixing the bottom cup and was able to add a stainless steel sleeve and drive the cup down into it. I shouldn't be surprised a 60+ year old gearbox is that worn out
And now the reason I'm on a GC thread telling you about this. I was also able to test fit the brush hog to the GC. She lifted it without a second thought...of course. LOL. I swear I heard the tractor ask me to hurry up and finish this thing already so we could go thrash some grass but that might have been my imagination.
I hope to get to paint stage later this week after building the front/back supports and tail wheel swing arm/bracket.IMG_20200830_134604.jpgIMG_20200831_204312.jpgIMG_20200831_204319.jpgIMG_20200831_204337.jpgIMG_20200831_211946.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #539
Starting to look like a bush hog being built-nice
Looking forward to seeing your finished brush hog completed, painted, and tested out.
Great work!
KC
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
White 6175 Work Horse Tractor (A59814)
White 6175 Work...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2021 Deere 333G (A53317)
2021 Deere 333G...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
