Cheap welding rods
   / Cheap welding rods
I know 7018 are supposed to be kept dry and I know 6010 don’t have to be kept in an oven but I think your not even supposed to put 6010 in an oven. If I recall the 6010 needs a certain moisture percentage in it to run correctly.
   / Cheap welding rods #12
Low Hydrogen electrodes like 7018, 8018 etc. Maintain their quality by being stored around 200 degrees. Others like 6010, 6011, 6013 actually enjoy a little moisture. Keep them dry but no need for the oven.
   / Cheap welding rods #13
I havent used a Hobart rod in years (actually since 1984) but at that time they welded very well. We used Hobart welding machines and rods on a chemical plant construction job doing xray quality welds and had no problems. They do weld a bit different from Atom Arc and Lincoln but not so much that they were a problem. I have no idea of the quality of them today though.
   / Cheap welding rods #14
Fire Power rods would currently be owned by ESAB and be likely a rebranded version of one of the lines like Atom Arc. But before that they were Victor/Tweco products. They wouldn't be cheap in the traditional sense.
Atom Arc 7018 has been my go to rod for as long as I can remember, the contractor I worked for only purchased it, and when I became the boss, its the only rod I purchased as well.
I havent purchased any in 5-6 years, I still have one fresh unopened can in my welding drawer, along with the remaining rods from the previous can in my oven
   / Cheap welding rods #15
I guess the 5P+ is good for stuff around the house, I was a pipe welder for 30 years. Lots of heavy wall and high pressure applications, I tried to put a stringer in with a 5P+ once and threw them in the ditch. Just give me an old regular 5P (red rod) and a Lincoln 7018 or 8018BL or a 9018. Of course I was never on a job where they would let you run a 5P stringer down hill, that's only application the 5P+ has a decent use.
   / Cheap welding rods #16
Lincoln bought an entire company to get the rights to a 7018 rod they wanted to sell,,
Weld the Lincoln right next to a Hobart,, you will toss the Hobart,,
I am a pretty good welder, (training and everything!! :confused2: ) , but, i can not keep a Hobart 7018 rod welding,,
I complained about them at the welding supply place that sold them to me,,
The guy said if I was a "Real Welder" that I could keep the Hobart rods welding,, :(
Weld your fence (or shop shelf) with 7014 ONE TIME,, you will not use anything else,,, :eek: ` ~ :D
I have an AC welder, and always have a hard time getting enough penetration. I like 6011 rods - not so much 6013. Does the 7014 penetrate better than 6013?
   / Cheap welding rods #17
Yes. But keep in mind that the reason most people don't get proper penetration is lack of technique, not the rod. And keep also in mind more penetration means nothing if you have slag entrapment and improper fill. I've welded dog bone ends on a tractor back on with 6013 and never had an issue. Used to do it regularly for the FNH dealership I managed. Seemed no one else could ever weld. These went back mostly on industrial tractors that were abused badly and the balls were falling out the ends and we replaced them with weld on ends with the balls in them.
   / Cheap welding rods #18
No. There are many proprietary differences between rods of the same classification but of different brands. Weld with a Hobart 7018, a Radnor 7018, and a few other cheap ones, then go get a LINCOLN Excalibur. Big difference.
I honestly do not think there is much of a difference.
When I worked for the railroad I flew all over the world and had to us the welding rods that were available, and they all welded the same.
To me this is no different than diesel fuel we put in our tractors. it all comes from the same pipeline, but some tractor lovers swear by BP and sweat at Irving, where as others swear by Irving, and at BP. The little differences that they put in additives that make it different just before it goes onto the truck do not really make a difference. It is just people fall into marketing ploys.
7018 is 7018, is 7018...
   / Cheap welding rods #19
Actually, no, there are several classifications of 7018 within the 7018 class. But again, there are different compositions of rod chemistry between brands. A 7018 (or 6010 for that matter) isn't a 7018. They have to meet certain "specs" for each classification of 7018, but companies definitely have leeway in choice of and amount of certain arc stabilizers, deoxidizers etc. No, they don't all weld the same. Heck, even the flux color varies before and after the weld. Old 7018's used to have a yellowish, glass like flux. There are even AC versions of 7018. I've welded with 7018's side by side in some testing, and given the same settings, I can tell you they don't weld the same. They don't even list the same amp ranges across brands.
   / Cheap welding rods #20
True That. And not only do they run differently in the same AWS Classification they have other properties like H4R and H8R. Some have Low Manganese and others have Military specs etc. So they can run very different and have many different recipe's but still fall into the broad AWS Spec for 7018.
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
1997 JOHN DEERE 544G WHEEL LOADER (A52472)
1997 JOHN DEERE...
toro turf sweeper (A50324)
toro turf sweeper...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2013 FORD F650 ROUSTABOUT (A52472)
2013 FORD F650...
