Kubota trailer light connector
   / Kubota trailer light connector #11
John, sounds like the simplest solution is a cabbed tractor!!. And don't use the excuse of working in the woods, skidders have cabs :)
   / Kubota trailer light connector #13
Here is a solution that may work for you,
AuTow Brake Trailer Brake Controller for the Trailer
I'd be tempted to use a 3 sided box open at the bottom to mount a cheaper control in.
That could be an interesting solution. (But wow, what a price.) When you think about, that's really a great way to handle trailer breaks: no matter which tow vehicle you connect to, you have brakes on the trailer. I wonder how they detect a brake pedal push in the tow vehicle - or maybe they don't and just assume that any deceleration calls for braking? (Which would probably work OK with a proportional controller in over-the road situations.)
The only downside I see is that it's a proportional controller. I greatly prefer proportional for over the road towing: it gives much smoother operation than the time-delay based brake controllers. However, proportional controllers can be a problem for off-road use: the rougher the terrain, the more they get confused. This is why time-delay based controllers tend to be more popular with off-roaders.
I installed the Redarc Tow-Pro Elite controller in my antique military pickup: it's used both on-road and in the woods. The controller has selectable modes for proportional or time-delay control. (It's also the one I referred to earlier which the box installs remotely with just a knob on the dash to control.) Not weatherproof, unfortunately.
   / Kubota trailer light connector #14
What did the dealer charge to add that connector?
I had it "thrown in" among other things after getting total price, but I'd be surprised if the kit (brackets, plugs, wiring) was over $60 and as far as installation, plug and play, bet it was installed in 5 minutes and took longer to unbox it and take the plastic off it than install it.
KUBOTA HB84 HYD HOPPER BROOM (A52709)
KUBOTA HB84 HYD...
KBH Tender Trailer (A56436)
KBH Tender Trailer...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SUV (A59231)
SUV (A59231)
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
