hydraulic Oil Dye, Where To Get???
   / hydraulic Oil Dye, Where To Get??? #1
drizler
My Massey has a sight glass. Great theory lousy in practice. Ya just can稚 tell if it痴 under or overfilled. Do they make dome sort of visibility dye for hydraulic oil ? Thanks
   / hydraulic Oil Dye, Where To Get??? #2
My local JD dealer stocks it. I've never checked at my local Farm Store? A Google search will give you many options as well.
   / hydraulic Oil Dye, Where To Get??? #3
I use JD dye,about $8,make sure you tell your service tech that you "didn t'"use automatic trans fluid!
   / hydraulic Oil Dye, Where To Get??? #4
I just noticed my local JD dealer conglomerate thought parts prices weren't high enough so they raised the prices!!!! IIRC directions state i jar per each 5 gal capacity I utilized 1 jar for of dye for each of my JD 4255(14 gallon capacity)/Kubota M7040(cap 10.6 gal) & can no determine hyd oil level easier
MT3668 HYDRAULIC OIL DYE ADD 9.06
Got it, thanks . I always wanted a sight glass until I finally got one��. Nowdays I’ll take a good old fashioned stick any day
   / hydraulic Oil Dye, Where To Get??? #6
I prefer a sight glass.
My little JD has one that is easily seen on the back of the tractor. I glance at it every time I walk past. Would I stop and pull a dipstick every time I walk past?
   / hydraulic Oil Dye, Where To Get??? #7
On the 2025R, dye would not help. Need 2 people: one to keep watch on the circular sight glass while the other is pouring oil in. Once you get to the top of the glass, you have no idea where the level is. Can stick a stick down into the hole and do some measurements and guesstimate where it is. That's what I've done.
Ralph
   / hydraulic Oil Dye, Where To Get??? #8
Ralph
Why would dye not help? For example, if the oil is dyed green you would add a little, look at the glass, add a little, look at the glass until you have it filled to the level you want.
If all you see is green in the glass you have overfilled. Which is where I'm guessing you are.
   / hydraulic Oil Dye, Where To Get??? #9
JD oil dye is red in color
   / hydraulic Oil Dye, Where To Get??? #10
The sight glass is the way to go. A little overfilled is not a problem. It won't hurt anything. A tip on the John Deere dye - it's really persistent. You don't have to use it every oil change, only every second or third.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
48" Pallet Forks  (A52384)
48" Pallet Forks...
JOHN DEERE 8245R LOT NUMBER 276 (A53084)
JOHN DEERE 8245R...
