Walkbehinds and side hills?
   / Walkbehinds and side hills? #1
IHDiesel73L
I have a 2 acre property and mow about 3/4 of an acre of it, a good chunk of which is my septic mound. The mound is built into a hillside and not far from the house so I don't like to let the grass get higher than 6-8" between mowings. The problem is the fact that north, south and east sides of the mound are quite steep-too steep for any kind of lawn tractor or zero turn. Right now I'm doing it all with a 22" push mower which cuts nicely, but its pretty labor intensive. I'm hoping that a self propelled walk behind might have a low enough center of gravity to navigate the side hills, give a nice cut and allow me to cut 36 or 38" at a time.
   / Walkbehinds and side hills? #2
I have the same issue. I end up on the push mower and weed eater while dear wife rides one of the ztrs.
Looking forward to comments.
   / Walkbehinds and side hills? #3
Can something like a sickle bar mower be used or is the mound in a confined space?
   / Walkbehinds and side hills? #4
We asked the same question to users of walk behind mower and there response was "they are man killers on rough terrain and hills" so we didn't purchase it. That's all we can add......
   / Walkbehinds and side hills? #5
OK, first off, you'll kill a push mower on a slope if you do it much. They sling oil internally rather than pump and can't do that on slopes. A little bit here and there is one thing, but they won't take much.
Maybe one of the new battery/electric push mowers?
Better would be to add some fill dirt and reshape the slope to something less steep.
Another option that might be possible, add some landscape/wall block and create a tiered wall. It won't have to be mowed and could be planted with some sort of low growing ground cover like Phlox.
   / Walkbehinds and side hills? #6
Good suggestions!!!
I would invest in terracing and get rid of mowing, and the mower, completely.
   / Walkbehinds and side hills? #7
Or just some larger crushed rock about the size of bowling balls. Place that on the existing slope a few layers deep with a layer of landscape cloth underneath.. Spray it a couple of times a year for weeds.
   / Walkbehinds and side hills? #8
There are some 4wd walk behinds now that you might want to look into. Trouble is none have a reverse; so, it needs to be fairly open to not require pulling them back.
There are some good battery self propelled walk behinds now. Stihl has a couple as do others. This is if you're worried about the oil slinging issues mentioned. Almost all our approximately 1/2 acre of lawn that we mow with walk behinds has some slope contend with. No problems. My wife can blast away nearly top speed behind the Honda and do it all in less than a couple hours. I would take about 3 times that long because I'd mow 1/3 and rest, etc. We have the Honda HRR and an old JD 14SB, both very good mowers and easy to start. Have a 40v Kobalt, but it does not cut as well as the 2 gas ones and is not self propelled. Rarely use it any more.
Just recently got a new Ryobi 40v "crosscut" walkbehind, self-propelled. It is so easy to run around on slopes and all.
Ralph
   / Walkbehinds and side hills? #9
Now, I've got to go and look up septic mound.
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
Light Tower (A52377)
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
