TODAYS SEAT TIME
   / TODAYS SEAT TIME #11,711
Nice that should keep the lawn mower busy in years to come but why is the grass brown already, you couldn't of had frost yet? They say Jack Frost might show up here this weekend,
I think the lower angle of the sun and all the cut Golden Rod gave it that color...
As for the stickering, the 3x8's (16's) are stronger in that direction and you can use less stickers doing it that way... The lumber came out really straight and the builder kept telling me how much he enjoyed working with it.
The headers were 6"x10", mostly 20' 6" long,
SR
   / TODAYS SEAT TIME #11,713
I could probably squeak a 21 footer out of it, but you know how much extra work it is to do something like that. I rarely need anything long like that, so I never lengthened the track.
I milled out some 15x15 beams one time, they sure were heavy!! I stay away from all that heavy work these days!!
SR
   / TODAYS SEAT TIME #11,714
SR
My son does, one reason why he'd rather saw cedar decking, me, I'll stay with my day job a couple more years.
   / TODAYS SEAT TIME #11,715
Got back to stone wall building and got within 20 feet of finish.
   / TODAYS SEAT TIME #11,716
Looks good! I assume you are harvesting your stones from your property?
   / TODAYS SEAT TIME #11,717
Thanks.
I am literally digging the stones up from the remains of the old wall that has been scattered and buried 5 feet on either side of original fence line over the centuries.
Our property records go back to the 1790's
I am then building with what I find where I find it so the old stones are mostly remaining where they started.
   / TODAYS SEAT TIME #11,718
Smoke has cleared and the weather perfect to work up a little sweat. Well actually my BX worked harder than I did. Cutting down, pulling down small cedar trees in the middle of a stand of larger fir and cedar trees. Most were getting hung up so I had to drop them straight down by cutting 4ft chunks from the bottom. The first one was hung up so I had to chain up and pull it out. Then I dug out all of the stumps.
IMG_5003.jpeg IMG_5004.jpeg IMG_5005.jpeg IMG_5001.jpeg IMG_4998.jpeg IMG_4999.jpeg
Probably hard to tell but working in a confined space on a terraced area on otherwise steep terrain. The propane tank is about 4 to 5ft higher in elevation than the tractor.
   / TODAYS SEAT TIME #11,719
One of the things I envy about you guys out east is all those great stone walls. Knowing how you come by all those stones for the most part, though, helps to temper that envy.
   / TODAYS SEAT TIME #11,720
Thanks.
In my mind that is a noble thing to do. Preserves and shows respect for the past and improves the present looks of your surroundings. :thumbsup:
gg
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2012 International 4300 Reefer Truck (A55301)
2012 International...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
Utility Trailer (A52377)
Utility Trailer...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
