LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,489
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
And a front wheel drive car with good tires will get you pretty much anywhere you want to go if you drive with a grain of common sense. AWD has been way oversold IMHO. Ground clearance was the biggest issue I ran into with FWD cars, especially if it was wet snow that built up.
So many people think that 4/AWD makes you invinceable. 4WD will get you going, but isn't going to help you stop.
It all depends on your roads and driveways, I always run 4wd/AWD with studded snows a front wheel drive can do fair with good tires but a couple of the hills on my way home will stop thema couple of times a year till the town crew gets out and sands it. And front wheel drive won't make my driveway most storms till I plow and sand.
And 4wd wisely used will help you slow down when it is really slick, if you use your engine to slow down a heck of a lot better then abs.
