kubota L3400 HST Wont Start
   / kubota L3400 HST Wont Start #1
stelth11111
kubota L3400 hts
Tractor Turns over Will Not Start.Keeps Blowing 5amp Fuse.Any Ideas? Thank You. number 5 fuse.
   / kubota L3400 HST Wont Start #2
Which fuse is blowing would help diagnosis. Possible a shorted out or bad glow plug?
glow lamp-key stop fuse
   / kubota L3400 HST Wont Start #4
You seem to have the problem narrowed down. Check the glow plugs snd any involved relay. Check the wiring for inward migration of mice. 'Tis the season.
   / kubota L3400 HST Wont Start #5
You could unplug the glow plugs and see if that keeps the fuse from blowing. That would tell you if the problem is glow plug related or the stop solenoid.
   / kubota L3400 HST Wont Start #6
Well since the glow plugs will draw about 20 amps each so about 60 amps, I don't think there is any reason to check the glow plugs because a 5 amp fuse is blowing. However the fuel stop solenoid would bear looking in to .. :)
   / kubota L3400 HST Wont Start #7
What about the glow plug control circuit? That should not pull over 5 amps.
   / kubota L3400 HST Wont Start #8
My bet is on a mouse chewing a wire bare...
Either 5, 6, or 7...
   / kubota L3400 HST Wont Start #9
I would try to find the fuel solenoid and unplug it. Then see if the fuss blows. I think there could be a relay that's also a part of that circuit but it's most likely not too easy to get at. At least on my Kubota you have to pull part of the dash to get at them. Chances are you will need to get to the relays. If not a mouse or shorted wire a relay probably burnt up and is drawing too much current. The good news (at least on my Kubota) is they are just generic relays you can buy almost anywhere. The shape may be different but as long as the terminals on the bottom at the same it'll work just fine. I used a 30 amp relay for fog lights for a car when my glow plug relay died. I might of had to cut one off (the one that's connected when the relay doesn't have power).
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
Informational Lot - Shipping (A51039)
Informational Lot...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
