6013 vs 7014 vs 7018
   / 6013 vs 7014 vs 7018 #11
I've found too that different manufacturers rods weld differently. I don't do a lot of welding but I weld mostly with 7018AC. They are a more difficult rod to weld with. My reasoning is that if I weld with those rods then my skill level is reasonable when I do need to weld with a 7018. I've found that a Lincoln 7018AC welds a lot better than all the other brands of 7018AC that I've tried, so I buy Lincoln rods. I use AC rods because I don't have a DC welder and 7018's on an AC welder are just about impossible to weld with. I could do it when I was younger but those days are gone.
   / 6013 vs 7014 vs 7018 #12
i use lincoln 7018ac also, but on my dc rod positive setting. Makes a very easy weld on my machine. I nearly always get a great weld. I have used it on ac settings for thinner metal, but find it hard to strike a start on ac.
Me personally find that I can run 6011 DCEN on thinner material than I can run 6013.
Oh wow really, that's surprising, I wonder how come?
thinner metal you might try AC welding instead of DC. AC seems to work better on thin metals. But my mig works even better.
Grs, my welder is DC only. But, I dunno if you mean welding on an AC machine or using it on a DC welder, per your last comment here. I think I'm doing ok welding on 1/4" with just regular 7018, I don't have too many problems with it. I haven't really welded with it with a purpose yet, just messing around practicing.
You're doing it like training for fighting, bang like crazy in training so that it's easier in the ring or cage.
   / 6013 vs 7014 vs 7018 #16
Mine is an ac /dc machine. You can run 7018 on either. Ive been told if the material is thinner (like 1/8” steel) , running that rod on ac side works better than reverse polarity dc. But ive never tested that theory as i use the mig for thin stuff. But, whatever works is good enough. 1/4” material works great on dc reverse polarity. My welds come out looking great.
   / 6013 vs 7014 vs 7018 #17
I wondered if it has to do the the freeze rate of the filler material. the 6011 being a faster freeze rod.
So with straight polarity, less heat goes to the metal and more to the rod, meaning less penetration before the weld freezes, and 6011 is a faster freeze rod compared to 6013?
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Tractor Tires and Rims (A56860)
Tractor Tires and...
