Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #1
Tmanning03
Mahindra MAX 26XL
2014 Mahindra Max 26XL bucket will not lift at all. This is the only function on the front loader hydraulics that will not work.
I have bled lines, refilled, maxed out, changed lines, etc etc. I assume it has to do with the Besko HDMO3/2 (drawing of valve attached) spool valve but I cannot find any diagrams on the spool valve or any replacement parts. HELP!!! I have removed the floating spool and do not see any internal issues but im by all means no hydraulic mechanic, should there be some O rings in there?
It could be easier / cheaper to replace Besko Control Valve HDMO3/2 with something like Prince so I could get parts but that could be expensive and I would have no clue what model would compare.
Thanks in advance!!
Tucker
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #2
Does your joystick have cables? Have you tried reversing the lift and dump hoses on the loader? If the bucket then lifts and will not dump then it could be a broken cable. They can rust out due to moisture in the sheath.
I have reversed the hoses and the bucket does not dump. Hoses were switched and no change. This is why I assume it痴 in the hydraulic control and is more than likely to do with the spool valve i.e. internal 登 rings or ??
I really appreciate the help and response though!
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #4
Thanks in advance!!
Tucker
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #5
The Besko Control valve on my Mahindra 4550 4wd 4L loader busted the cover cap off the Spool regeneration got a new cover on it and then it busted the cover off the Spool Floating side. Seems something is wrong inside the valve. I have contacted several so called Equipment dealerships for some help and get the same thing we will be in contact with you in 24 hrs. i have yet to talk with anyone i want name them but i know who i can't depend on and for sure want buy anything there. Now to my question can you tell me a brand and model # that i can get to replace the Besko valve. It's crazy what Mahindra wants you to pay for one of those. i have only 160 hrs. on the tractor/loaded. Thanks in advance for your help, Stan Brantley
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #6
Thanks in advance!!
Tucker
I'm going to try ebay 2 Spool 21GPM Hydraulic Directional Control Valve for Tractor Loader w/Joystick | eBay
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #7
Did it work?
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2015 Chrysler Town & County Van (A55853)
2015 Chrysler Town...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
