Bubbling Interior Ceiling Paint
   / Bubbling Interior Ceiling Paint
A moisture problem with paint is not always from a leak. It can be because the humidity is higher on one side than the other. The moisture will move to the drier side, pushing off the paint in the process.
I did not know that.
The ceiling is open to the attic.
Would it be worth it to warm the top side like with a hair dryer as its a small area?
   / Bubbling Interior Ceiling Paint #12
Just check that there is the same amount of insulation over that area as the rest of the attic. You stated that there was a light fixture in that area. Has the ceiling box been removed & the hole sealed up?
The light box is still there not sure on the insulation level as I have been moving it around to work on things in the attic like run a new wire to that box.
   / Bubbling Interior Ceiling Paint #14
Took me 40 years to learn, prime everything! I知 building a new house so, PVA over green sheetrock and I知 gonna shoot primer over that! I know, overkill but, cheap labor!
Primer is good. I知 told Kilz is best so that痴 what I use.
Someone suggested I change the settings on my I pad to stop the hieroglyphs. Lost the post but I知 going to try anyway.
Go to Sherwin Williams. Their products are top notch. They also have a sandable, knockdown primer that will give you great results.
   / Bubbling Interior Ceiling Paint #15
Another cause can be that warm moist air is escaping from the room & then condensating around the opening in the attic during cool weather. Seal around the box & any openings inside the box.
   / Bubbling Interior Ceiling Paint #16
I have been painting homes for over 40 yrs and all the things mentioned can be causes but most likely it is from heat from the ceiling light fixture.I literally have scraped and patched around hundreds of lights over the yrs. if attic insulation is sparse that also creates more heat reaching the drywall. if it were a water problemthere would be brown stains.
I might have heat issues from the light, but it’s a LED bulb so I don’t think so.
   / Bubbling Interior Ceiling Paint #18
how old is the home?
2006 KENWORTH W900L (A53843)
2006 KENWORTH...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
2018 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2018 DRAGON...
