Can I leave my Kubota 3901 in 4WD?
   / Can I leave my Kubota 3901 in 4WD? #1
CindyCRNA
Member
Near Kansas City Kansas
L3901 HST
We have 20 acres we just bought along with a new tractor. I have 5 square feet of flat ground and the rest in some form of hill. Some shallow, some I won't be mowing any time soon, if ever, with a tractor. I have a whopping total of 7 hours on the tach but am wondering if this is hard on the tractor. I do have maybe 3-4 acres that is flatish that would probably be fine in 2WD but have seen some videos of folks mowing a hill in 2WD vs 4WD and the 2WD started skidding down the hill with a rear tire slipping (not sure what was going on with the other 3 tires as the camera was only looking down on 1 rear tire). All I'm doing is pulling a 5' brush hog currently. Thoughts? Sorry for the newby question.
   / Can I leave my Kubota 3901 in 4WD? #2
In general leave it in 4wd unless you are solid pavement. For the safety reason you mentioned when operating on hilly terrain, and of course traction. if on concrete or asphalt, you can shift to 2WD. You may operate on flat grassy or dirt surfaces if they are mostly flat, but DON"T forget to put it back in 4wd when ascending and especially descending on hilly terrain. So again, in general leave it in 4WD most of the time is the norm.
   / Can I leave my Kubota 3901 in 4WD? #3
As long as the ground surface is loose and allows the tires to slip in turns you should be OK. Obviously, don't do it on pavement, concrete, etc, or you can cause driveline damage.
That said, nothing you described seems to exceed the intended "on demand" setup for 4WD on that tractor. I have a similar mix of hills and flat, as well as mud and firm ground. When I know I will need 4WD I pull up the handle. It's not a major production to go in/out of 4WD on these tractors.
   / Can I leave my Kubota 3901 in 4WD? #4
Good advice above. That said, I would occasionally take it out of 4wd for a bit now and again so it doesn't get "wound up".
   / Can I leave my Kubota 3901 in 4WD? #5
Enter you new tractor make and model into your T-B-N PROFILE.
   / Can I leave my Kubota 3901 in 4WD? #6
Fully agree with the above advice. The only time that I ensure that I'm in 2WD is when I'm 'on the road', which basically means that you are 'at speed' (high revs+high range+pedal to the metal).
   / Can I leave my Kubota 3901 in 4WD? #7
I let traction be my guide and only turn on 4WD when I need it. Less ground damage and less wear and tear on the tractor that way.
   / Can I leave my Kubota 3901 in 4WD? #9
l leave it in 4wd when mowing because it seems like the tractor drives a little smoother when brush hogging my field, probably because the front wheels are helping pull the tractor iver the bumps and ridges.
   / Can I leave my Kubota 3901 in 4WD? #10
As other already said...you may want to run 2WD every now and than keep rod/cable free up.
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
Kubota L3130 (A53317)
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
