Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #15,801
You could get the tin man from Wizard of Oz or rig up some sort of lubrication tank on the side of your winch tower and use some of the old motor oil you got kicking around...
Thats probably what it would take, maybe grease would last longer. This is a vertical splitter but I like standing up so I keep it horizontal. this winter I'll bring in the shop and take the wedge apart, looks like 8, 1/2" bolts holding it on the beam, I think most vertical splitters are the same way...
   / Tractors and wood! Show your pics #15,803
I got 3 more loads in this afternoon makes it 13, only 15 needed to get to bare ground again, 20 will take me to June. Finally a feel of fall in the air and I could keep the wood stove going......
   / Tractors and wood! Show your pics #15,804
That sounds like some pretty nasty firewood in the making...
It's just to lube the beam, and with just a couple drips per cycle, it wouldn't be bad at all. Besides, the oil burns
   / Tractors and wood! Show your pics #15,805
My splitter has a grease zerk on each side of the push block. I also have a taller thin wedge, it doesn't push the split open as far as the more wedge shaped splitters, but it is a little less resistance through some of the big pieces.
   / Tractors and wood! Show your pics #15,806
I had forgotten about it, but my father used to put a light squirt of grease on the beam before using his. I have that splitter now, so better start doing the same.
Hey OldPath, how big is a load? 20 bucketsful isn't much, 20 dumptruck loads is quite a bit. We used to fill my father's KB5International_side.JPG several times over the course of the day but we were just cutting it on the cordwood saw, he split and stacked it later.
   / Tractors and wood! Show your pics #15,807
There must be a ware bar behind the zerk. I'd have to be careful putting a zerk on my wedge cause the wedge is going through the wood. Yes there is more resistance that way, it's worse on frozen wood, a little pressure and bang the wood sometimes flies apart where as thin wedge is more likely to slide threw........
   / Tractors and wood! Show your pics #15,808
Hey OldPath, how big is a load? 20 bucketsful isn't much, 20 dumptruck loads is quite a bit. We used to fill my father's KB5View attachment 674359 several times over the course of the day but we were just cutting it on the cordwood saw, he split and stacked it later.
I'd like to have a truck like that in 4 wheel drive........
I need 15 of these trailer loads.......
The trailer fills my my 3'x4' wood cart up 3 times......
   / Tractors and wood! Show your pics #15,809
The brickyard had a 4 foot splitter with a wide wedge. When a stubborn piece released on that, you did not want to be standing in the way!
   / Tractors and wood! Show your pics #15,810
Here it is when new.
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
1629 (A57192)
1629 (A57192)
