Gate Openner for 16 ft Steel Tube gate
   / Gate Openner for 16 ft Steel Tube gate #11
I've had an MM installed for 10, maybe 15 years now. Used it for a while while I was still working so open/close twice a day. Lately I only use it a couple of times a month. Mine's on a battery too, but I ran the 12VDC line from my low voltage yard lights to the opener and it keeps the battery charged.
I home made a very light weight gate though using chainlink fence toprail and fittings.
   / Gate Openner for 16 ft Steel Tube gate #12
Keep in mind that the cell phone use is for allowing remote opening. If you get a phone call, see a delivery truck or guest on the security camera you then open the gate from wherever you are, on the road, office, etc.
   / Gate Openner for 16 ft Steel Tube gate #13
That makes more sense to me now. Thanks
   / Gate Openner for 16 ft Steel Tube gate #14
   / Gate Openner for 16 ft Steel Tube gate #15
Not sure I would want the E8 gate opener. Especially if you need to use solar. The control panel doesn't have a built in solar charge controller like the Mighty Mule. I have had very bad luck with add on charge controllers and the one built into my Mighty Mule system has worked flawlessly.
The JSJ site says they are the US importer so I assume they are made in China.
Here is their FAQs page. Frequently Asked Question | JSJ ProTech LLC
   / Gate Openner for 16 ft Steel Tube gate #16
There are so many varieties of gate openers that it requires the right knowledge to make the right choice for your requirements. When you are looking for the automatic gate opener, you have to understand a few factors like what kind of gate you have, the load of the gate, power source, installation, and control. It is only by understanding these parameters you will be able to determine your needs and find the model that fulfills that needs.
Mighty Mule is probably the most popular automatic gate opener. According to the manufacturer, it can handle gates with a maximum length of 18 ft and a weight of 850 lbs. Yes, it comes with remote control. So you don稚 have to get out of the car.
Its look and specification suggest that it is suitable for residential buildings, farms, ranch, small warehouses, etc. It works with all types of gates, including chain link, wrought iron, wood, tube, vinyl, etc. However, it is slower when compared with other gate openers, but it is acceptable because it can handle heavy gates with ease.
   / Gate Openner for 16 ft Steel Tube gate #17
I have the Liftmaster solar powered medium duty gate openers on my farm gates. They work good for my limited use. At most 3 times a day.
My neighbor used them for frequent driveway use and also installed electric locks. They worked fine for about 5 years and then became a monthly repair annoyance. They didnt handle heavy use well. Funny things can affect their reliability. I installed one for a customer and he had trouble with prevailing winds keeping the gate from reaching the lock successfully. Another wanted solar power, but his spot didn’t have enough sun. Frequent use killed the batteries and the solar panels counldnt keep up
   / Gate Openner for 16 ft Steel Tube gate #18
Welcome to TBN
:welcome:
Richard
   / Gate Openner for 16 ft Steel Tube gate #19
Thank you Richard:)
   / Gate Openner for 16 ft Steel Tube gate #20
The USAutomatic 020320 Sentry 300 Commercial Grade Automatic Gate Opener is another popular gate opener that I have heard about. Gate works with AC supply as well as the solar panel. My friend was saying that this may be a good gate opener, but not the cheapest. It also accommodates a battery which is useful in case of a power outage, but it is not included in the package. You will have to get it separately. It comes with two remotes that work perfectly within 3 feet of it. The range is more than enough. The only thing it doesn’t have is that it does not have is an on-off switch. Works with both heavy and small gates.
Hyster H225E (A47384)
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2008 Chevrolet Malibu Sedan (A51694)
2008 Chevrolet...
43030 (A51691)
43030 (A51691)
