Montana 4340 Front End Loader Bucket Stuck in Down Position
   / Montana 4340 Front End Loader Bucket Stuck in Down Position #1
jonathandnielsen
Montana 4340
I was shredding with my Montana 4340 and had my loader and bucket raised. As I was shredding the bucket suddenly fell all the way down like the cylinders were pressurized. My first thought was that something broke on the joystick but I found no issues there. I checked the quick couplers and they were all seated fine. I swapped them around the loader would lift no matter what coupler I used. But the bucket couplers would not work no matter what coupler I used. I took the couplers off and fluid comes out of all of them. If I take the pressure out of the system I can get the bucket to go up but it always falls if nothing is holding it up. If the bucket is flat on the ground, I can lift the front end of the tractor off the ground and lower it back down. I'm at a loss at what could be the issue. Could it still be the valve/spool even though the loader works on both couplers? Bad cylinders? Let me know if there is any information that I missed. Thanks!
   / Montana 4340 Front End Loader Bucket Stuck in Down Position #2
The only time I have ever seen a bucket or loader boom fall quickly it was because a hose burst. I would think that is something you would notice right away.
I do not think you have a valve problem based on your troubleshooting procedures. Are you positive there is not a external leak of fluid somewhere?
   / Montana 4340 Front End Loader Bucket Stuck in Down Position #3
Sound like the piston came off one of the rods.
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
