B2650 rear tires, tube or tubless?
   / B2650 rear tires, tube or tubless? #1
zlock24
New Martinsville, WV
jd 445, kubota bx1500,wheel horse c-160, wheel horse h-520
Are the rear tires on a B2650 tubeless from the factory? I have a leaking valve stem and I was curious whether I just needed to pick up a valve stem or a whole tube.
   / B2650 rear tires, tube or tubless? #6
I guess no one on this forum understands why the tires are tubeless. The benefits vs issues with tubeless are my question I have put tubes in all my tires and haven’t had a problem since. Other than the oblivious cost cuts are there benefits for tubeless?
   / B2650 rear tires, tube or tubless? #7
Or perhaps you are simply unwilling to accept cost savings as a manufacturer's reason for eliminating a part that is perceived by them as being unnecessary?
Enjoy your tire tubes. Just like tubeless tires, there are valid reasons to use them.
One advantage you gave up is the ability to use tire plugs on small leaks.
   / B2650 rear tires, tube or tubless? #8
Being able to plug leaks often without removing tire from machine. On the B20 rear tire plugged nail and tine punctures with methanol filled ballast. They were filled tubeless tires. Of course air filled tires are easier to plug.
Had a time where I had a lot of valve stem leaks from the rubber cracking on trailers, trucks and equipment. Switched to bolt in valve stems. Use bolt in valve stems in any thing that runs in mud. Maybe old age talking but rubber valve stems or tubes don’t seem to last as long. Use more slime type sealants in non-highway equipment to decrease the repair down times.
   / B2650 rear tires, tube or tubless? #9
[wQUOTE=DIYOrangeDave;5852964]I guess no one on this forum understands why the tires are tubeless.
One advantage you gave up is the ability to use tire plugs on small leaks.[/QUOTE]
Bingo, again.
Punctures in air filled tubeless tires can usually be easily plugged externally.
SDT
   / B2650 rear tires, tube or tubless? #10
Care to elaborate why?
That is an odd response. OP asked a yes/no question and Rick gave a yes/no answer. The OP didn't ask why.
If we start requiring people to elaborate on simple yes/no questions we're going to run out of server space. It's like asking if Kubota paint is orange and then expecting details.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
