Ford 1920 90yr measurement of wooden clutch pedal spacer
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #1
Atvjoe
Miami, Florida
Ford New Holland 1920 Yr 1990 With loader SMC 84Q
Hi to all, does anyone have the Wood Block clutch spacer measurements, so I can make one. I have searched with no luck. My tractor sits for a good while and I don稚 want the clutch to stick in this Florida weather. Thank you all for your help..
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #2
I don't use a block but one of the cheap bar clamps from Harbor Freight. They are not good for a lot more. This is the best and highest use.
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #3
there is plenty of good info here to explain the mechanism, once that's understood then one realizes even small short piece of 2x4 just work as the OEM plastic jobby.
   / Ford 1920 90yr measurement of wooden clutch pedal spacer #4
Find the spot where the block goes. Push the clutch pedal until the clutch is released. Take a measurement.
Thanks for the info
Thanks to everyone
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
CATERPILLAR CS563 SMOOTH DRUM ROLLER (A51246)
CATERPILLAR CS563...
2024 KMC 7406 LOT IDENTIFIER 11 (A53084)
2024 KMC 7406 LOT...
