2210 Rebuild Success/Breakin
   / 2210 Rebuild Success/Breakin #1
Tole
Member
Yanmar ym2210d
Happy to say I started and ran my tractor after my rebuild of replacing the crank, sleeves, and 1 piston and rod.
Thanks to the forum and all who answered questions.
I ran it about an hour at half throttle to heat it up and check for leaks and get the loader back on and re-torque the head.
Should there be more break in period underload maybe and when is best to change the oil after this period?
   / 2210 Rebuild Success/Breakin #2
Only an opinion but I would treat it as normal use including oil change. :2cents:
   / 2210 Rebuild Success/Breakin #3
I would also recommend re-torquing the head gasket again after some more use until the bolts don't move anymore. Sometimes it takes a couple/few cycles for those gaskets to completely settle in.
   / 2210 Rebuild Success/Breakin #4
I like the idea of re torqueing the head after a few heat/cool cycles. While in the process you should probably check your valve adjustment. It may change slightly when you torque the head. I'd probably change oil at about fifty hours, similar to a new engine.
   / 2210 Rebuild Success/Breakin #5
YES YES YES :thumbsup:
New rod, piston and rings. That is the right path to take.
PALLET OF LIGHT BULBS & PIPE VICE STAND (A52708)
PALLET OF LIGHT...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
Yukon Jack Skid Steer Bucket Attachment, 46" W x 48" L, Asset# 70 (A59076)
Yukon Jack Skid...
205196 (A52706)
205196 (A52706)
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
2010 MINI Cooper (A56859)
2010 MINI Cooper...
