Anyone have a solar generator?
   / Anyone have a solar generator? #1
RichZ
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
I don't have many power outages, but when I do, the gas generator is a pain. Noisy, needs periodic maintenance. I have enough gas engines, I'd love to eliminate one. Besides, if you don't have power in your area, where are you gonna get gas???? Solar generators seem like the way to go. Anyone have any experience with them, good or bad? What models would you recommend?
Thanks!!
   / Anyone have a solar generator? #2
If you don't like maintaining a gas generator, you are not going to like maintaining/replacing batteries, especially for power outage only, use. I had a 48 volt bank of batteries to run a big telecom Inverter, but the batteries basically died before they were ever really used. Now I want to use the 48 volt batteries in my JD E-Gator.
   / Anyone have a solar generator? #3
I was hoping someone would state what is a solar generator. Never heard of one.
I assume it is simply a set of batteries and solar panels?
If that all it is, it will have to have pretty big battery storage to supply a house load for any length of time. Even the wall storage batteries that Tesla and others are now selling, is going to have limited "run" time for the house.
Having said that, Lithium batteries, and there are many different Lithium chemistries being used for batteries, are completely different from lead acid batteries. Lithium batteries, especially LiFePo chemistry, are game changers. Lead acid batteries have very serious limitations and really are a consumable product if the battery is being used. LiFePo batteries should last decades of use but that is just a guess since they have not been in use for decades. LiFePo batteries are roughly half the size and weight of lead acid batteries for the same amount of storage. But they actually have more usable storage compared to lead acid.
Lead acid batteries should not use more than 50% of their capacity. Using more than that seriously degrades the lifetime of the battery. Furthermore, it takes quite a bit of time to fill up a lead acid battery. From 50% to roughly 80%, the battery can be filled pretty quickly. After roughly 80%, the battery takes less power so it takes more time to fill to 100%. Failing to fill the battery before drawing down the power is called Partial State of Charge(PSOC). Using a lead acid battery that has not been fully filled, ie, the battery is in a PSOC state, will degrade the capacity of the battery and its life. However, solar power is just what a lead acid battery needs to fill up. A long, slow charge from the sun. However, that means that the battery gets to roughly 80% early in the day so that the rest of the day can be used to fill up the battery.
In the boating world, since it is so hard to fill up a lead acid battery, a safe design point is to assume one would only use 30% of the capacity of a lead acid battery. LiFePo batteries can use 50-80% of it's capacity without serious degradation of the battery's life. Most/Many lead acid batteries have a cycle lifetime of 300-500. A boater using these batteries to supply the boat for it's "house hold" needs is likely to have to replace the batteries in 3-5 years of full time use. One of the LiFePo batteries I know of says that with 80% of the battery being used each cycle, the battery will last 3,500ish cycles. If the battery bank was sized to be cycled every three days, those batteries might last 30ish years. :shocked:
LiFePo batteries are very difficult to catch on fire. There is at least one video of a battery maker shooting and them tossing the battery into a fire to try to get the battery to burn. The battery does not burn. That is with LiFePo chemistry. Other Lithium batteries will burn and burn bad. It is the problem Boeing had with their plane. When I was looking at the Tesla wall battery, they only said it was a Lithium battery. No way in hades would I put a non LiFePo battery on my house. If a Lithium battery catches fire it will burn my house to the ground. It is very unlikely that the local fire department could save the house since they would have a very difficult time putting out the battery fire. In Europe, some of the fire departments have dumpsters that will hold a car. They plan on filling the dumpster with water and then somehow putting a car with burning Lithium batteries into the dumpster. :shocked:
Batteries are seemingly simple but very complex. :D:laughing::D
Later,
Dan
   / Anyone have a solar generator? #4
You'd have to have lots of batteries and a big inverter. Our diesel generator is fairly low maintenance and sips fuel compared to a gas generator. Ours uses 0.25 gph for an average of 2-2.5 kw while it is running. Uses about 2.5 gallons for the year just starting up for maintenance for 15 minutes every 2 weeks. Gotta have a battery tender on its starting and panel-running battery. Needs oil/filter change about every 200 hours (long time) and coolant change at 10 years along with fuel and air filters.
Our Isuzu 12.5 kw one is a gem.
Ralph
   / Anyone have a solar generator? #5
We are considering a 15kw battery coupled to 10kw of panels, cost is about $23k and are guaranteed for 10 years, 15kw should enable us to run everything normally and still receive some income for infeed to the grid.
There are quite a few batteries apart from tesla now so it is competitive.
   / Anyone have a solar generator? #6
I look forward to getting my Isuzu 12.5 Onan project finished! It is the smoothest Diesel I own. Well maybe beside my Duramax.
I just learned about solar generators the other day. They are basically solar panels with an inverter and a lithium battery. I haven't found any big enough to run a whole house, but I just want one to run a few things, including my c-pap at night. It hasn't happened where we live, but we know people who have had power outages for days in their areas, and obviously, gas stations were out of power too, so they couldn't get gas for their generators. So...solar generators sound like they may be a good thing, and I wondered if anyone on TBN had one.
   / Anyone have a solar generator? #8
Check out Tesla Powerwalls. 13.2kwh/battery, 5kw sustained output, 7kw surge. They can be charged either by solar or by a generator.
They can be integrated with any solar installation, although Tesla has some good combination pricing.
Not cheap, but they don't need maintenance, and there are no fuel costs.
All the best,
Peter, who is in the process of having several installed.
   / Anyone have a solar generator? #9
The technology has to advance a WHOLE bunch before I sign on to buying a bunch of over priced batteries with a short shelf life/cycle life.
Energy is still to inexpensive to substantiate that much return investment.
Next door neighbor has an array of 15K and says it's just a money pit.
Unless you have no recourse.
   / Anyone have a solar generator? #10
I feel sorry for people that have no concept of electrical loads. And then get dupped into solar power. Historically, (around here in the North) they then have to go out and buy more panels, and later a generator.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
