325 Snowlower Drive Belt Tension
   / 325 Snowlower Drive Belt Tension #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
just had first snowfall. Currently getting a little rubber aroma from drive belt in heavy snow. too tight or too loose? how tight should I adjust. Thoughts?
   / 325 Snowlower Drive Belt Tension #2
Can you give us the model number of the blower?
Richard
   / 325 Snowlower Drive Belt Tension #4
I had a 42 snow thrower on a Deere 325. Had the same thing happened and it was the belt that drives the auger on the blower (vice the belt from the tractor to the auger drive shaft).
I pulled the cover and found the area full of grease from greasing the drive shaft. I cleaned the whole housing out and put a new belt on it. Never slipped again.
Do you have the owners manual for the thrower? If not, check Deere publications for a down load.
   / 325 Snowlower Drive Belt Tension #5
can't find Model # , it the JD 42 inch, single stage snowthrower.
Without the model number, it is hard to look up the user manual.
Can you post a few photos of the unit?
How is the main drive belt tightened?
Richard
2014 Chevrolet Tahoe (A52377)
2014 Chevrolet...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
