Snow Suggestions for a cab on GC-1705 (Canada)
   / Suggestions for a cab on GC-1705 (Canada) #1
gc1705
Massey Ferguson
Hello,
I am thinking about getting a Cab for my GC-1705. Is the "Original Tractor Cab Enclosure" a reasonable solution? Are there others to be considered?
Thanks
   / Suggestions for a cab on GC-1705 (Canada) #2
I've seen many comment that it likely wouldn't hold up to living in the elements but as a garage kept item works well for a reprieve from the elements throughout the winter. If you're looking long term hard top then sims and curtis industries both make one.
Thanks for the info
   / Suggestions for a cab on GC-1705 (Canada) #4
I use the Berco soft cab, easy to put on and easy to take off with lots of viability from inside cab. Draw backs-its the forward and rear clear plastic can wrinkle duing storage. Its very tough, had it for 4 winters now.
I prefer the soft cab because in the summer a hard cab can go where I go.
My dad is the same on his Kioti 36hp but he keeps his tractor outside. Berco is a Canadian company.
Thanks for the info :)
   / Suggestions for a cab on GC-1705 (Canada) #6
I love my OTC Can. Going on 9 years and no problems. I suggest getting the safety glass front window.
   / Suggestions for a cab on GC-1705 (Canada) #8
Does the back window open or is access possible to the chute crank on a 3 pt snowblower?
   / Suggestions for a cab on GC-1705 (Canada) #9
It does not have an opening, I use an electric chute deflecter and chute rotation for mine. I did have to cut the plastic slightly so I could get the switches installed for the bracket and wiring. The bracket I installed is just two half inch aluminum angle pieces that pierce through it.
You can do the same for the manual rotation handle if its long enough, if not the doors on both sides can be unzipped enough for you to reach the handle-or you can cut a flap.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2018 LEDWELL LW48HT2-10 PB-LP (A52472)
2018 LEDWELL...
