hydrolics work, forward motion doesn't. Mitsubishi MT 2201
   / hydrolics work, forward motion doesn't. Mitsubishi MT 2201 #1
Patrick McAnish
Mitsunishi MT2201
I am having problems with the drive train on my MT2201. I know this is the Japanese version. I have been told the closes US model is the Satoh S670 Bison. My problem is my hydraulics for the front bucket and rear scraper and PTO work but after about 50' of under powered forward motion the tractor stops, though the engine remains running
This is an all hydraulic system and 2/4 wheel drive. Fluid lever is good and clean. Filter has been cleaned. Clutch seems to be functioning but I think this is a dual clutch model, though I don't know what that means. I have had a mobile tractor repairman look at it ( he not very good) and he does not know what is wrong. Thought I'd try you guys for some clues.
   / hydrolics work, forward motion doesn't. Mitsubishi MT 2201 #2
Same in 4wd?
When is the last time you replaced the fluid?
Any noises?
Ok, turns out it was not a hydraulic problem but a clutch problem. Adjusted the clutch and all is fine. Apparently it was just barely engaging when cold, enough to move the tractor 50 feet of so, which made me think Hydraulics. Thanks for the comments.
   / hydrolics work, forward motion doesn't. Mitsubishi MT 2201 #5
That should have been fairly noticeable when shifting.
No, it did shift but not smoothly. I've only had it for a short time, thought it just shifted that way, Now it shifts much better.
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
1839 (A51248)
1839 (A51248)
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
air compressor (A55758)
air compressor...
2012 Chevrolet Traverse SUV (A55853)
2012 Chevrolet...
