Collant dripping off oil pan 2008 TC30
   / Collant dripping off oil pan 2008 TC30 #1
Murkman
Yakima, Wa
New Holland TC30
Coolant dripping off oil pan 2008 TC30
I've got a coolant leak which drips off of the oil pan. Checked hoses (ok). Can not see coolant coming from region of the water pump. The lower front corner of the block (right front) is wet. Stuck a endoscope camera in and around and can't tell where its coming from. Is there a freeze plug on the front of the block? And other ideas where the orgin may be
TC30 Engine exploded view.gif this is what I'm working from.
All is good is good at that spot. Seems to be more located near the front of the block on the side with the oil filter.
   / Collant dripping off oil pan 2008 TC30 #5
Most water pumps have a weep hole outside of the seal to indicate when the seal is bad. Keep in mind that the leak will occur when the system is under pressure and the cooling fan airflow will blow coolant and oils in a far different location from the point of origin. It may be a radiator leak, core or cap, being blown back.
Constant drip. Even with the radiator cap removed. Looks like the only way I will get eyes on where the coolant is coming from is to tear out the radiator. I'm thinking I will top off the coolant before every use between now and then. The tractor is only needed for occasional snow removal.
   / Collant dripping off oil pan 2008 TC30 #7
Pressurize the system first and locate the leak before you take anything apart.
Pressurized or not the leak can not be observed. Therefore tearing it down is left as the last option. Maybe there will be a major failure before then and I will know where the problem is.
   / Collant dripping off oil pan 2008 TC30 #10
You need something like this and more motivation.
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
